Results 1 to 10 of 16
Thread: Who is NOT using an EPIA?
    Constant Bitrate ose-ml320's Avatar
    Oct 2003
    Baton Rouge, LA (USA)
    Been lurking for a while so I know why most people, at least it seems like most people use EPIA MB's (power, heat, size, cost, etc.). Now that I have started to buy parts, I need to make a decision, but I'm still struggling with the mini-ITX vs other sizes debate, ie mini-FlexATX, and wanted to know what else are people using, and why (pros/cons) did you choose it over the popular epias?
    [ fingers crossed that this isn't flame bait ]
    Scott
    MCS-PC
    Epia M-10000
    XP Pro; 512MB; 60GB (2.5")
    Panasonic Slot SlimDVD/CD-RW
    7" Lilliput (Touchscreen)
    Casetronic C137 w/ 90W PSU (Temp)
    19V Laptop Adapter (Temp)
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Quote Originally Posted by ose-ml320
    I am using a shuttle SN45G. Still somewhat small. I wanted to the have the AGP slot so I could also use the system for playing games. Well how often do I sit in my car and play games? Not very. So it really isn't worth it in the long run. So if I was to do it over again I would have gone with the EPIA. And thrown in a PS2 if I really felt like I had to play games.
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    I am using an EM586, it's kinda small too, my entire unit is about the size of a CD ROM drive.
    Not bad for a 4 year old motherboard.
    Variable Bitrate craigyb's Avatar
    Sep 2003
    UK, Sale, Cheshire
    Original CarPuter was a laptop P133 32MB ram
    Next a BookPC, bit of a disaster.
    Next Shuttle PIII 866Mhz 512MB, works like a charm, additional Serial ports added.
    Next CarPuter will be based on a ChyangFun Cell box. Athlon XP2000, 512MB RAM.
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    I'm about ready to scrap my EPIA M9000 and get a microATX mb, probably an ASUS running a 2.0 GHz Celeron. The size is comparable and the power/heat shouldn't be too bad. The EPIA is just too unstable as far as the drivers and running CPU-intensive programs, and too sensitive about connecting many peripherals and most brands of RAM.
    With all my components (mostly USB) hooked up now, I've just started getting the dreaded IRQL_NOT_LESS_OR_EQUAL BSOD. There's no way to fix this except to remove the offending driver(s), and if I do that I won't be able to run my touchscreen, DLink radio, GPS, ATI remote, wireless LAN, etc. Most of the drivers for these are unsigned and not approved for WinXP.
    Also VIA has been very poor as far as support goes.
    Sorry for the rant. I'm frustrated with the EPIA. Its only advantage is its size and power, and it's starting to lose that.
    Jul 2003
    So Oregon
    Im using an embedded PC (SIngle Board Computer) for mine. 400mhz k62 with built in LCD and touchscreen controller 2x PCMCIA slots USB and TV tuner.
    Its going in my car next week, just doing some finishing touches on my interior.
    I have a source for these complete units uncluding a very nice 10.4" touchscreen for around $350 (1024x768 200 nits). Included 4gb hard drive too.
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    I am using espressoPC (www.saintsong.com.tw) and since it can take unregulated power from 9v to 15v, it's the perfect PC for me in my car.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Used to use an EPIA but now it's in a VCR shell in the family room.
    This is what I use now.
    My new toy...the FIC Samba-1845...
    Still in the building process as far as OS. (DLing M$ Media Center as I type this.)
    Link has all the info...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Variable Bitrate Mitokondria's Avatar
    Apr 2002
    Sunny Florida
    I decided to go against an Epia and went with a micro atx board. I started taking measurements and once you add the pci riser card to the epia board it ends up being almost the same length as a micro atx board. Its just a couple inches thinner on the width. Now I have the power of a celeron chip with a low rise 3 slot pci card.
    - 3+ years & still no carputer!
    - Done collecting parts
    - Currently planning setup
    Jun 2003
    Atlanta/Augusta, GA
    mATX MSI 845GEM w/ P4 2.4Ghz
    I wanted the extra pci/agp slots and a faster CPU.
