Results 1 to 5 of 5
Thread: Converting 50pin slim cd to 44pin laptop hd
    Sep 2003
    Brisbane, Australia
    Question Converting 50pin slim cd to 44pin laptop hd
    I have a Teac CD-224E Slim Cd-rom that has an adapter screwed on the back. The connection on the adapter looks like a mini-ide 44pin but has 50pins on it. I want to run this to a USB 2.0 laptop hd adapter which has the 44pin mini-ide connector. Do the first 44pin coincide with the mini-ide or are they in a different config??? What are the extra 6 pins for?? Sound??
    Any help would be appreciated
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Does it look like the one in this thread if you search for slot load?
    Where to find the CORRECT laptop CDR/DVD to Desktop IDE Adapters
    Or is it a different kind of header.
    Sep 2003
    Brisbane, Australia
    These are pics of the USB 2.0 adapter and Cd-rom
    sorry they are so blurry but i'm only using a webcam
    Sep 2003
    Brisbane, Australia
    Smile Slim CD rom to USB 2.0 HD adapter
    I pulled the adapter board off the back of the CD-rom and did a quick comparison (from what I could see) to the laptop HD pinouts. It looked as though it would be pretty much spot on so I connected it up. The USB 2.0 adapter plugged straight on the back leaving pins 44-50 vacant.
    I fired up the laptop (which is only USB 1.1) and the CD-rom worked a treat!!!
    This enables me to mount the slim cd-rom in the dash while the pc is behind the passenger seat.
    Jan 2003
    Ruston, LA
    I'm glad it worked out for you
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
