Results 1 to 10 of 13
Thread: 5.1 in a car?
    Aug 2001
    Auburn Hills, MI
    Wink 5.1 in a car?
    Ok Ok.. So I was driving down the road, thinking about my DVD-ROM that I bought off ebay and I thought to myself.. is it possible to have something like Dolby 5.1 in my car. I've got two front speakers and two back speakers and could easily hook up a center speaker and a sub. I just would need a sound card with 5.1 decoding, easy enough to find. So my question is .. has anyone done this before.. or atleast tried it maybe with out the center speaker or even the sub??
    I have a 98 honda civic and I have an OEM HU. I doesnt' have the IPBUS like other HU (at least I don't think it does) but it does have a wire harness that is easy to hack and has a spot for front left, front right, rear left, and rear right speaker inputs. So it could be a 5.1 - 1.1 Dolby if I don't put in a sub or center speaker... Does this make any sense to anyone? Anyways .. I think it's might be a good idea....
    Hack Your Car
    www.CanBusHack.com
    Jul 2001
    Richmond, VA USA
    Post
    I would definately include a sub just for the pure fun of having explosion rumbling from your car at stoplights. But really, I have seen a picture of a car on sounddomain.com that had either a tweeter or small coaxial speaker mounted on the rear view mirror for a "center channel" (wasn't used for 5.1 or anything though, just to improve the front soundstage.) An interesting idea though might be (and I have no expirience with the 5.1 soundcards... its just an idea) if you could get the two front speakers to mimic a center channel... kinda like 3d sound processing on a computer. It might not sound as good for effects that go from left through center to right, but it would be a nice alternative to trying to add another speaker somewhere. Of course if you don't mind it sticking out it would be best to mount one right over your screen so when there is dialouge and such it looks like the people are speaking from the middle of the screen and not the left and right at the same time... which is what some 3d sound is like. It's an awesome plan if there is an easy way to do it without spending lots of money... just try it and keep us all posted. Im sure someone out there has done it though, give it a week and see if there are any replys on specifics.
    Josh Karger
    By reading this post you agree to overlook all grammatical, spelling, and typographical errors! ;)
    Sep 2000
    Saint Peter, Mn
    Post
    A center channel doesn't really work in a car. I have one and it's hard to hear against the other speakers. Right now, I have it set to come out the front (left/right) speakers.
    Nov 2000
    Ottawa, ON, CA
    Post
    Originally posted by Dragyn:
    <STRONG>A center channel doesn't really work in a car. I have one and it's hard to hear against the other speakers. Right now, I have it set to come out the front (left/right) speakers.</STRONG>
    The center channel doesnt work because you don't have it set up properly.
    Center channels most certainly work in cars .. it's just a heck of a lot more difficult to properly set up than one would think. For starters, your center channel should be louder than the right/left speakers .. mind you, only slightly louder. Secondly, the left/right channels must be time-delayed very very slightly (to make it seem as though the speakers are positioned further away from the listener than they actually are.
    There is more to take in to consideration .. and it becomes very elaborate. In short, center channels _do_ work .. they work very nicely .. but you have to set it up correctly, otherwise, it can hurt your sound quality (sound staging).
    -James-
    Tech tips and more - http://www.techguys.ca
    *NIX command for today: rm -rf /bin/laden
    Sep 2000
    Saint Peter, Mn
    Post
    I know all about time-delays and SQ (one reason I don't use mp3s as the main sorce).
    The problem is the center speaker. It can't handle it and probably never will. You only have so much space to work with. I would have a 6.5" center channel to go along with the others but due to space limitations, I don't!
    The only way to make it sound decent is to turn down the other 5 channels. This to me is not the way to go. I don't use it that much to be worried about it. That's why (as I said earlier) I use the Front L/R ch's.
    Nov 2000
    Ottawa, ON, CA
    Post
    Ouch. You need to invest in a reasonably powered amplifier to drive the center channel.
    I have a center channel in my car and it sounds perfectly balanced .. so you might look into properly driving the center channel.
    -James-
    Variable Bitrate dbinnc's Avatar
    Sep 2001
    Greensboro, NC
    Thumbs up
    I have 5.1 in my car. Check out the Rockford Fosgate Dolby Pro-Logic II decoder. Pro-Logic II is the next step in pro logic and does 5.1 with full frequency rear. it's not digital, but its your car, who cares, it rocks!
    Check out my car here My Car
    D http://www.2k1civic.com
    Nov 2000
    Ottawa, ON, CA
    Post
    Pro-Logic II is just a gimmick. It "creates" a rear-fill using a set of algorithims (similar to Pro-Logic) .. it is by no means is true rear-fill.
    For the record: I've got AC-3, DTS and Pro Logic. I'm using the pioneer AVM-P9000R master unit with the 6 DVD changer. VERY good sound .. the 5.1 is VERY noticible.
    As per turning all the other channels down .. how the heck do you tune your system? Let me guess ... no EQ, hence no tuning. On high-end EQs, you tune the system DOWN .. not normally up ..
    ANyhoo .. tested my car last night with an RTA .. prefect flat response at 2db of separation per deviation
    -James-
    Sep 2001
    Greensboro, NC
    Post
    I don't really agree with that.
    http://www.dolby.com/ht/co.br.0107.P...nersGuide.html
    I also have a Audio Control Model11 System 90 Center channel amp with full EQ onboard.
    D
    Nov 2000
    Ottawa, ON, CA
    Post
    You can disagree all you want .. but until you educate your self further, you will continue to disagree blindly.
    ProLogic |CREATES| rear fill .. it is |NOT| a decoder nor a recording scheme. It is therefore an interpolation that mimics true rear fill.
    ProLogic II may be a little more advanced .. but it still is |NOT| surround.
    A simple review of quadraphonic recording schemes will confirm this.
    PS: Full EQ on board? What, a 6 band EQ? or is it 6 pre-sets?
    [ 09-27-2001: Message edited by: JamesB ]
    -James-
