Results 1 to 6 of 6
Thread: 5.1 channel Sound cards with onboard toslink (not in the add on case)
    Constant Bitrate psyclobe's Avatar
    Oct 2003
    U guys know of any high quality sound cards that do all the multi media and have all the adjustments via software-and that also have a digital toslink onboard on the card? I'm planning on going digital from the sound card to the deck (an alpine PXA-H700) and I just have no room for any add-on external deck unit that comes with most high end cards that have digital out on them.
    I'm looking at sound blasters latest offerings on tomshardware.com:
    http://www6.tomshardware.com/video/2...audigy-01.html
    He says
    "The card has the two standard input circuits (line and mike) and a digital output on a 3.5*mm jack, that can be used with Creative sound systems that have digital input. It can also be used with any other standard digital equipment through an adaptor cable."
    I wonder if that digital 3.5mm jack can be converted to toslink to then go to the back of the alpine.
    Suggestions?
    -Jason
    Jan 2003
    Ruston, LA
    Quote Originally Posted by psyclobe
    Suggestions?
    -Jason
    Yes
    3.5mm mono to rca adapter then one of these
    http://www.ramelectronics.net/html/a...s.html#pof-820
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Newbie Bob_Barker's Avatar
    Dec 2005
    Oxnard, CA
    confused
    isn't the whole point of the toslink to have lossless media until the alpine unit converts the signal to analog? it seems that you are going to add more connections (see also: more noise) I am wondering if one of these would fit your bill.
    EMU 0404
    -or-
    EMU 1212
    Unfortunately they are only stereo cards, not 5.1. bummer.
    Apr 2006
    ESI Juli@ is an option.
    From their site:
    Built in digital optical output - 5.1 Dolby digital support
    - Digital coaxial I/O (with support for up to 192kHz) - 5.1 Dolby digital support
    No idea if that means it does DTS though, I presume it's a given if it does DD 5.1?
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Quote Originally Posted by Durzel
    From their site:
    DTS and DD5.1 are different products. If there is DTS, there's a good chance the lower DD5.1 is also available, but DD5.1 does not usually imply DTS.
    As for converting digital 3.5mm to rca to optical, no noise is introducted because it remains digital. There should be no loss of quality in converting digital on the rca to digital over optical since it's just the medium that's changed.
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Jun 2006
    If I'm not mistaken, those 3.5mm jacks that are dual-purpose are analog/optical outs, using the 3.5mm TOSlink adapter. So you wouldn't need to convert to RCA then to optical, because the adapter converts the port straight to a standard-size TOSlink port.
