Results 1 to 10 of 10
Thread: Power Button
    Variable Bitrate bjm2020's Avatar
    May 2003
    Louisiana
    Power Button
    Is there something special about a pc's power button that makes it work?
    I just got one of those shifter knobs that has four buttons on top to turn things on and off.
    I tried taking a power switch off of my old case and just connecting the power and ground to the shifter knob but it doesn't work.
    It works fine with any other device so I know the knob is working.
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    All you need is a "short" on the two pins on the motherboard for it to turn on...If it's ATX.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    May 2003
    Louisiana
    what do you mean by a "short"?
    How could I do this?
    Constant Bitrate mugu's Avatar
    Oct 2003
    San Antonio, TX
    a simple jumper would work, but wouldnt be convient =P a switch short the circuits when pressed down, so any emulation of the sort should work. Ive used switched of all sorts to boot my atx motherboards.
    Jan 2003
    Ruston, LA
    you need a momentary on switch
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    May 2003
    Louisiana
    thats what i thought. Another 40 bucks waisted cuz i didn't research something before i bought it. oh well, i'm just gonna buy a few momentary switches.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by bjm2020
    If you can take apart your switch it's very likely that you can convert it to momentary on. (if it's pushbutton or any type with a spring)
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    May 2003
    Louisiana
    The thing is, the button doesn't control it, it sends an rf signal to a little processor which then turns the accessory on or off so I don't think that I could change it.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Press the button twice quickly?
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    May 2003
    Louisiana
    i tried that already
