Results 1 to 5 of 5
Thread: boot problem with epia m
    Newbie jemmons's Avatar
    Sep 2003
    philly
    Question boot problem with epia m
    hi i just got my new Epia M motherboard in yesterday and i went to test it out in my c137 case with 90w power supply and i couldn't get it to boot past the loading windows screen. I was using an old 10 gig drive with windows 2000 on it and a stick of 256 mb of ram. I have the drive set to master. I wanted to test it out in my house before i moved it out to the car. I switched out drive cables, another hd with xp on it, RAM, even another power supply. But each time i got the same results. It just hangs at the black screen that says loading windows. I tested the drive out on my other computer and i got it to load fine. I was wondering if anybody had any ideas as to what the heck am i doing wrong. i want to get this thing working before i order the rest of the parts for the computer.
    Constant Bitrate reggiek945's Avatar
    Apr 2003
    Oklahoma
    Quote Originally Posted by jemmons
    Just curios, did you install the operating system from scratch or was it already on the hard drive when you placed it with the Epia? If it was already on the hard drive you may have to do a clean install.
    Reggie
    Sep 2003
    philly
    Quote Originally Posted by reggiek945
    Reggie
    the os was already on there. i was using it as a testing drive. I was thinking about wiping it. i just wanted to see if i could get it to work with out having to do that.
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Most likely you need to do a new install. Windows does a hardware check during the install and there is probably a conflict between the mb/cpu for the current installation and your new EPIA.
    Sep 2003
    philly
    Quote Originally Posted by wi77iam
    thanks that fixed it. i wiped the drive and re installed the os and that fixed it. It loaded right up. I just took it out to my car to test it and it worked perfectly. i really like the new media engine. thanks again for the help.
