Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Thread: Cold Weather vs Hard Drive
  1. #41
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Fortunately it's 76F pretty much every day of year here in Sunny SoCal.
  2. #42
    Nov 2004
    Seal Beach, CA
    Yeah rando - unless you travel to places like Mammoth and Tahoe during the winter... then it can get awfully chilly!!
    2004 Toyota 4Runner Sport 4WD
    Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
  3. #43
    Constant Bitrate dingofarmer's Avatar
    Oct 2004
    colorado
    Quote Originally Posted by TruckinMP3
    Denver is similar for temps, Several days have been that cold. My HD did just fine, A little bearing noise until the temp came up. It hit boot RPMs every time.
    Well, I'm not that worried then, I'll just definitly make sure the heat is on. I have a feeling that it is going to be a cold one this year.
  4. #44
    Nov 2004
    Michigan
    maxtor
    I bought a Maxtor 7200 rpm 60 GB HD off ebay with FDB unfortunatly...
    Operating (C): 5 to 55
    Non-operating (C): -40 to 71
    stats from: http://www.memory4less.com/m4l_itemd...itemid=2552383
    I am in Michigan, it gets cold here...
  5. #45
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    In my case I have a engine block heater that plugs in to 110 outlet, I believe smaller cars with diesel have them too. If it is cold enough to heat the engine might as well heat the pc also off the same power source. I have been thinking of using a light bulb with a gaurd around it in the pc case. Just have to figure out bulb size and ac/dc current.
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
  6. #46
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Quote Originally Posted by Hammer
    EVERY standard pc component that we use in carpc's (screens, hdds, motherboards, cdrom drives, pci cards, etc) will be out of its listed operating temperature range when faced with a northern climate in winter. Some deal with this without a hiccup, my entire system meets this requirement at the moment, where as I have issues with motherboards in older setups, not harddrives, regardless of whether they had a FDB or were 6 years old. Even components of the same make and model can varry due to the manufacturing process, so its all a bit hit or miss.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
