Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: Cold Weather vs Hard Drive
    Apr 2003
    I've seen other threads where people try to figure out what's happening to their computers in cold weather, but I have a more specific question:
    What hard disks are you using that boot in cold weather at all?
    At the moment, I have a Maxtor Model 8 6E030L0 30GB 7200 RPM drive. At exactly 35 degrees F, when I turn on the car (typically in the morning) the POST will report 'Primary Hard Disk Failure'. After 5 minutes or so, I need to unplug the power (for lack of a switch) and restart the computer and it works fine. Checking the spec sheets from Maxtor, I see that the Operating Temperature is rated at a minimum of 41 degrees.
    On checking other drives from other manufacturers, they all have similar operating temperatures. I was wondering what drives you use that either 'beat' their rated temperatures or what methods you use to avoid the problem.
    Thanks in advance,
    --Ed
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    I have a Maxtor... Denver cold weather has not been a problem in 3 or 4 years. Most of that was parking on the street (not garaged overnight).
    Sometimes the cold causes a bit more noise until it warms up.
    TruckinMP3
    Read the FAQ!
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    i live in upstate, NY.. it can get very very cold. I've booted my maxtor 60gig on a -15F morning.
    '98 Explorer Sport
    80% done
    Apr 2003
    Could you guys give me model numbers of your Maxtor drives? It dawned on me that mine has a feature called "Fluid Dynamic Bearings" or something intended to reduce noise output.
    Jun 2002
    Colorado
    Mine is an old 8.4gig... sorry I am not going to pull it out to look at the model number... No "Fluid Dynamic Bearings" though.
    TruckinMP3
    Read the FAQ!
    FLAC guitar333's Avatar
    Jun 2003
    IDAHO
    ****, i have a 40gb IBM 7200rpm (not installed yet) it would suck if cold weather will be a problem. IT SNOWED LIKE 2 FEET ToDAY
    92 Taurus SHO - Daily driver - Epia M10000 80GB 512mb 7" touchscreen, Opus PSU etc
    93 Black SHO - 30mpg cruiser
    90 Silver SHO - 419whp fun/project car, CarPC to come (for tuning)
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Snow...stupid Arizona. Today's low was like 50. Heat might be an issue. We'll see in August.
    Jun 2003
    IDAHO
    as least you can use fans, but what do i do on the -20F days here if my hard drive doesnt work well in cold weather
    Sep 2003
    Austin, TX
    Just overclock an Athlon XP with Palamino core. That'll produce a good bit of heat...
    Jun 2003
    IDAHO
    i hope your kidding
