Here are some tips:
If you can look on the box itself, there is a white bar code sticker that also says EPIA M10000 followed by on the box itself a "Made In China" slogan , if beside that slogan there is an affixed green sticker -it is an Ezra-T core.
You can ask your retail outlet if they know before you purchase, if they're not sure ask them when they received the board in stock, if it is before April then it is probably then Ezra-T core.
If you have the opportunity to boot up the board then you will see it in the BIOS as Nehemiah.
If they have 2 versions of the EPIA M10000 the Nehemiah version will likely be at least $US 10.00 more expensive.
