You may try looking for an anti-stat coating that can be applied to the inside of the case...
You should be able to ground all groundable metal parts (i.e. PSU, motherboard, HDD, etc.) by jumping several wires around. It works best if you establish a central location in your box for the lead to the vehicle's frame. Run separate grounds from each component to this central location (could be a nut, barrier strip, whatever).
This cuts down on noise.
LinkBack URL
About LinkBacks
