Results 1 to 8 of 8
Thread: Dash Suggestions
    Jan 2000
    Alpharetta, GA
    Dash Suggestions
    Well I am in the process of adding to and modifying my system and I want to correct the dash piece. The last time I used wood filler because I found reference to it on the net that it would stick to plastic, and it worked, but it cracked over time.
    I am inclosing a pic so you can see the gaps that I have to fill. I have searched and found posts about bondo and fiberglass and "ultimate bondo." I don't know wether bondo or fiberglass are going to stick to the pastic of the trim piece.
    Suggestions?
    Thanks,
    John
    JohnRam
    Low Bitrate wylie-c's Avatar
    Oct 2003
    Canada
    Fiberglass should stick just fine. You can also use fiberglass reinforced filler too, but real fiberglass, the mat and resin, will be the strongest. Just use enough to join the pieces, and then finish it with body filler.
    Jul 2003
    Atlanta, GA, USofA
    Quote Originally Posted by wylie-c
    Yes, ditto.
    I used Bondo Long-strand fiberglass, then a normal Bondo Filler.
    http://www.seebq.com/gallery/carcomputer?page=4
    There are pictures of the process with both types.
    Good luck,
    Charles Brian Quinn
    seebq.com
    Jan 2000
    Alpharetta, GA
    Does the bondo putty stick to the plastic?
    Thanks,
    John
    JohnRam
    Dec 2001
    urethane panel repair epoxy
    or SMC/bumper Repair filler
    Newbie JeeP-3's Avatar
    Oct 2003
    Oman - Middle East / England for Uni
    What size screen is that? It's a good fit... F150 or Expedition?
    FLAC cproaudio's Avatar
    Aug 2002
    so cal 2 hours from everywhere
    That's the Xenarc/Gains 7" vga screen cover
    NEW complete and updated My project with 100+ pics on 7-4-03
    If you have a Shuttle FV24 motherboard in perfect working condition for sale, please PM me.
    Jul 2003
    Atlanta, GA, USofA
    Quote Originally Posted by johnram
    Yes, just make sure to sand off as much paint as possible (but only in the area that you wish to make adhesive), and yes, it will look very rough before the application of bondo fiberglass filler and bondo "putty" body filler, but it will be covered up.
    I will admit, I did use a little bit of epoxy to hold the monitor to the top of the dash while I applied the fiberglass. The epoxy was quickset, and took about 10 minutes to dry. I believe CptnDip**** mentioned: "urethane panel repair epoxy" as well.
    Just go for it!
    Charles Brian Quinn
    seebq.com
