Results 1 to 2 of 2
Thread: To extend my 5 wire touchscreen cable or not?
    Jul 2003
    So Oregon
    I got my center console glassed, everything is coming together except the touchscreen cable is 2 inches too short.
    I have some spare cat5 cable which is shielded and will work well to patch (solder) in a couple extra inches, but I'm worried about adding any resistance to the wires for a sensitive device like a touchscreen. Think its safe?
    I can't move the controller btw, it has an even shorter 20+ pin cable which is attached the the motherboard.
    I'm going to get some food, then probably start cutting. So post quick if you think its a bad idea!
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    Quote Originally Posted by e_fractal
    2 inch extension should be ok.
    if you are really paranoid, you can test the lengths of wire with a multimeter to see if your 2" length of wire will add much to the total resistance of the wire.
    if it was like 2 feet of wire, i would advise against it.
    ~Mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
