Results 1 to 2 of 2
Thread: Boot from Compact Flash with SATA adaptor?
    Nov 2003
    I've started looking into the possibility of booting from a CF type harddrive for a portable carputer. I found this site selling a CF adaptor to ATA that allows the drive to be recognized as a normal IDE drive.
    What I'm wondering, has anyone seen a SATA way of doing this? It seems that SATA would be a better choice for a new system. If anyone can point me in the right direction, I would appreciate it.
    Jesse
    Oct 2003
    Philly, PA
    how would useing SATA help? the max speads of SATA arent that much higher then modern ATA 133 vs 150, and i dont the read speads of CF cards are that much faster then a regular HD. plus if your useing it as a bootdrive it has limited numbers of write cycles, so if the computer uses it as virtual memory then it might not last to long.
    Pontiac Grand Am
    building CarPC useing BookPC and Lilliput 7 inch TS.
