Results 1 to 5 of 5
Thread: still blowing fuses
    Mar 2000
    Washington DC
    Post still blowing fuses
    Ok..i've been doing some troubleshooting and i've narrowed the blown fuses down to 2 things. Either the barrel plug or the slide switch. Im leaning towards the slide switch though. Its a SPST heavy duty Slide Switch rated 6A at 125vac...
    could this be the problem?
    --Nick
    btw: im using a 1amp fuse on my partsexpress 4" tft
    Aug 2000
    Post
    Try using a 5amp fuse... and check the wire they might be making contact with each other when the vehicle moves
    Aug 2000
    Post
    and how often are u blowing fuses?
    [This message has been edited by Kain101 (edited 02-12-2001).]
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    Post
    So you only blow fuses when the cord is plugged into the display?
    It is time to isolate, unhook the wireing harness from where it plugs into the LCD circuit board...at least on mine there is a four ping plug that has the power and video input.
    then just plug your power into that part of the wiring and play with the switch, if it doesn't blow, either you have a bad LCD or a miswired plug (and now toast LCD).
    http://www.geocities.com/mr_bubba_zanetti/
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    If your blowing fuses with a SPST switch, it's not the switch. Probably the plug. Barrel (phone) plugs short when they are inserted or removed.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
