If you are running Dos/windows95 or 98 do the following:
on another computer with the same OS go into
dos, insert a formated floppy and type
"sys a:"
prese enter.
After it is done do a copy of the sys.com program. For dos it will be in C:\dos. For Windows 95/98 it will be in C:\windows\command\.
i.e. copy c:\windows\command\sys.com a:
Then stick that disk into your mp3 computer. It will then boot to an A:\> prompt. Type:
"sys c:"
This will redo your boot partition and make it bootable again (hopefully) if the error is not a physical error.
LinkBack URL
About LinkBacks
ictures@128.8.187.126/d:/newdlls
