Results 1 to 5 of 5
Thread: Question about this enclosure
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    http://www.bixnet.com/usenforslcdd.html
    Why is there 2 firewire ports. Does one carry sound and the other data
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
    Maximum Bitrate Naamanf's Avatar
    Sep 2003
    Colorado
    Quote Originally Posted by churnopol
    stay away from this. I bought one about two months ago and all it did was send bad data from the DVD to the computer. Junk. I ended up with this and it works much better. http://www.caloptic.com/eus-b.html
    2007 Tahoe
    Opus with iBase 896 and Pentium M 735 Transflective Xenarc Alpine DVA-9861, PXA-H900, Sinfoni 45X2 (2) 90x2, Genesis Dual Mono, JL 1000/1 (2), Focal Be tweeters, ScanSpeak Revelator Mids, Dynaudio MW170, Dayton 12" Ref.
    My Install
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Edit: It appears that on the fist post the image and link are two different items. I have the product that is on the link not the photo
    I currently have the USB version of the link on the first post. It works flawlessly and if you are in a tight squeez (like I was) with space it works out perfectly. There are actually two seperate circuit boards connected by a short IDE cable. This allowed me to make an U shape bend save space on the bottom. I mounted mine vertically and the bottom was really close to the ground and I only had about an inch of space (even after i cut out some carpet) So this one worked perfectly.
    Feb 2004
    Menlo Park, CA
    I will explain what you see on the image you posted in the actual thread.
    On the far left that is an Audio Out port. Much like conventional IDE cd-drives this one has an audio out. Its pretty useless in my opinion.
    Next comes power, not gonna explain this
    The white squarish one is a USB-B port. This is for connecting the drive to the computer via USB.
    On the right are 2 firewire ports, they are both identical. One is used to goto the computer and the other is used to link to another firewire device in a daisy chain.
    Quote Originally Posted by Naamanf
    One thing about firewire. There is a widely known, atleast within the people I know, but not highly documented problem with firewire. It will cause "Write Delay Failrues" that can cause a loss or corruption of data. If you encounter this youd be wise to never use a firewire device on your computer, go USB instead. That being said there is no way to determine if it will work or not other than user testimony. I know for a fact that the onboard IEEE1394(Firewire) on the ASUS P4C800 Deluxe gives this exact error. On the flip side even with that same board when I use the firewire on my Audigy it works perfectly.
    Hope this helps.
    2003 Subaru Impreza TS
    Staus: Done.. too lazy to make pictures lol.
    Feb 2004
    Elmira NY
    no. most firewire devices have 2 ports not b/c you can use both to conect to your computer. but to chain 3 or 4 devises off one port
