Umm you shouldnt even have it on when you start the car- nothing should be on.. thats too much of a drain on the electrical system, your starter dont get enough power... your alternator only recharges the battery when hte car is running.. while starting the only thing that should make noise is starter.. again though, nothing else in the car should be on when starting the car.. it can damage the items (starting the car creates a huge voltage drop to anything running, then the voltage spikes back up to near 16volts then back down to 14.4... its your best bet not to even have inverter on when starting the car.
And the noise, try using one of those 3 prong to 2 prong adapters.. that worked for someone in the channels.. im gonna try it once i get my inverter back from statpower (it blew up, dont know how, dont know why).
LinkBack URL
About LinkBacks
