Results 1 to 7 of 7
Thread: Size of a 2DIN
    Nov 2003
    Size of a 2DIN
    Anyone has measure the space for a default 2DIN radio?
    I am on mounting stage and would like to know if itīs possible to fit my entire PC at a 2DIN. I need the width, length and depth in inches or centimeters.
    Thank you very much.
    Osvaldo
    Nov 2003
    Germany
    Hi I can't say it exactly but it should be about 18cm (7.1") length and 11cm (4.72") width. The depth is very different in different cars. These are only the measures of the shaft not of the frontblend.
    For more exactitude: google.
    Nov 2003
    I searched all around the google, but I couldn't find it, so I came to bother you!
    Thank you very much for the info.
    Best Regards
    Osvaldo
    Variable Bitrate craigyb's Avatar
    Sep 2003
    UK, Sale, Cheshire
    Shouldn't they be the other way around.
    7.1" wide
    4.72" height
    Depth - dependant on your car...
    Craig
    Audi S8 supercar
    Modded Xbox 400GB HD
    Rear 7" screen & navplus
    Toyota Hiace Van
    Shuttle PIII 866 256Mb 10GB OPUS powered
    MediaCar & Mappoint 2004
    Custom fit 7" TFT VGA TSK
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Look at phc's setup. he fits everything in a 2DIN space.
    Nov 2003
    Germany
    @ craigyb: sorry I muddled it.
    I even noticed that 11cm height are 4.3" not 4.72".
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    18x17.5x11.4 cm (7x6,9x4.5 in) at least these are maximal proportions I could use valid for continental version of Renault Laguna II (>2001)
    Hope this helps
    P.
