Results 21 to 30 of 38
Thread: Audigy / Audigy 2 audio question...
  1. #21
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    P.S. your install is looking great.
    car computer rev 5: 8" lilliput and usual suspects
  2. #22
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    tahnks... and no.. not choppy playback w/the nx, choppy playback w/all the onboard crap
  3. #23
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    Hey russ it's coming along very nicely. I noticed you have VGA and composite, what's hte composite hooked up to? do you use a tank circuit? I've got the same PSU.
  4. #24
    phc
    phc is offline
    Variable Bitrate phc's Avatar
    Aug 2003
    Quote Originally Posted by robiewp
    choppy on the audigy? slow the system down?
    there was a defect with the USB2 driver iteration (my opinion) that caused the NX to use a ****load of horsepower. on my dual processor system (the other machine i have an NX on) running the nx with the usb2 driver eats almost all of one processor's power. On the mini itx? my solution: roll back the driver. The original driver supports up to 4.1, which is what I actually have and use.
    I picked up the NX last night to replace my Sonica Theatre. The sonica worked most of the time, but just keeped ****ing me off when I would reboot, XP would give me a "usb device not recognized" and I would have to unplug the USB cable and put it back in before it would get it.
    Anyway, I installed the NX, updated the firmware and drivers from the website and DVD playback is really bad, I can hear the dvd spin up then spin down, audio is choppy and the video update is every 2 seconds.
    With the Sonica, DVD playback was flawless, so I know its the NX. Now the DVD drive is USB 2.0 and not connected thru an external hub, like the NX. I should try using the older drivers. What version of the drivers did you roll back to?
  5. #25
    Dec 2003
    Massachusetts, US
    I started from scratch and ONLY installed what was on the CD (no downloads or firmware upgrades). This is the one thing that really ****ed me off about the creative. With the original driver everything is really great, but with the update, unless you've got an entire processor to spare on audio processing, it's crap. Creative should know better.
  6. #26
    Constant Bitrate reggiek945's Avatar
    Apr 2003
    Oklahoma
    Quote Originally Posted by Pudge
    I'm assuming you had to open up the case to supply the 5 volts, that's an expensive piece of equipmen to void that fast. Is that just off of a standarad molex, the black and red [black being gnd red being 5v (I'm almost positive yellow is the 12v. line, correct me if wrong)] connecting to the + and gnd of the unit? Is this correct, and do you have pictures of how you did it if it's not what you did.
    SO which wire for the 5v? Is it the red wire for the 5v? I have the audigy 2 nx also and wanted to install it correctly. Thanks inadvance.
  7. #27
    Jul 2002
    San Rafael, CA, USA
    pudge - I've got the composite hooked up to the lcd's in my trunk shown in exhibit a
    (exhibit a)
    no tank circuit.... i'm actually gonna scrap the psu and get an opus... i'm starting to run a bit short on power. w/all the crap i have hooked up, I'm pulling around 7A off the 5v rail (i also just added a pci geforce4 this weekend)
    robie, phc, i'm using only what came on the cd.. haven't tested a dvd yet though cuz my lazy *** hasn't dug around my backseat to find one
  8. #28
    Dec 2003
    Massachusetts, US
    words cannot express how much you suck.
    Let me know where you live so i can come take those screens off your hands
  9. #29
    phc
    phc is offline
    Aug 2003
    Ok, I reinstalled the drivers that came on the CD, but I cannot undo the firmware upgrade. DVD playback is better, but not perfect. I didn't notice a 4.1 option in the NX setup, it goes from 4.0 to 5.1.
    Wondering if you have a USB DVD player?
    Maybe its time to check out the Philips Aurilium. Ugh.
  10. #30
    Dec 2003
    Massachusetts, US
    ugh. you're right. i'm using the 4.0 and having my 5 channel amp do the crossover for the sub. I am, however, using 5.1 on my comp in the house with no problems, with the firmware update and usb2 updates... but it's using almost all of the resources on one of the processors in my desktop
  1. Epia Onboard audio Vs Creative Audigy?
    By KMPorter in forum General Hardware Discussion
    Last Post: 10-26-2003, 01:57 AM
  2. audio interface question
    By evank in forum General Hardware Discussion
    Last Post: 06-06-2002, 07:34 AM
  3. Question about audio system for CRV99
    By blahblah in forum General Hardware Discussion
    Last Post: 11-13-2001, 03:56 PM
  4. audio cable question
    By daver in forum General Hardware Discussion
    Last Post: 10-04-2001, 01:04 PM
  5. Sound card / mpxplay / DOS question
    By vBanshee in forum General Hardware Discussion
    Last Post: 09-09-2000, 02:04 PM
