Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
Thread: Flash card bootable drive?
  1. #11
    Jun 2003
    Chicago
    I think there are some algorithms availble on Microsofts website designed to reduce the number of memory writes to flash disk
  2. #12
    Maximum Bitrate eugenen's Avatar
    May 2002
    Ohio
    My EPIA 5000 takes about 20 seconds to post so I don't think I can get down too close to 22 secs. I've only been using linux for a couple months so I'm not the best for optimizing it either. My main advantage with my current setup is eliminating the need for any shutdown system. I've simply set the MB bios setup to power on as soon as it sees power.
  3. #13
    Sep 2003
    Wilkes Barre, Pa
    Thanks for the replies.. After doing a little research it seems the only solution for running an OS off a CF is Windows Embedding which I'm still not 100% sure is read only but seems to be.. Microsoft puts out a eval version that I'll test out once I get my system together but buying this OS seems out of the question as it's for OEM device builders only..
    I think my 1st try will be storing my OS on the CF and running it off a RamDrive.. I wish the mini-itx boards supported 2gig of ram.. It would make this option more appealing..
  4. #14
    May 2002
    Ohio
    Quote Originally Posted by The Durango Kid
    You mean the only solution for running a Windows OS not the only solution for an OS period.
  5. #15
    Sep 2003
    Wilkes Barre, Pa
    eugenen I stand corrected.. Yes for running a Windows9X or greater OS..
  6. #16
    May 2002
    Ohio
    You mean Windows not windows 9x or greater . IMHO Linux is greater than Windows
    Sorry couldn't resist.
  7. #17
    Sep 2003
    Wilkes Barre, Pa
    Well for the most part I have to agree but I only program in VB and .NET so my program wouldn't work in Linux so that rules out Linux as an OS (unless I run and emulater which I really don't want to do)..
  8. #18
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I would agree too that the best thing to do would be to get one of those solid state (flash) hard drives. Like a laptop IDE drive. I've seen them up to 2 gig. It would be better to get a drive that is actually made to be used as a hard drive than to get a compact flash card with an IDE adapter and piece something together. I've seen a 2 gig drive on ebay for $85 bucks before, so if you can find the good deals, that would be the way to go.
  9. #19
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    $85 will buy you an 80 GB western digital hard drive with an 8MB cache. Or for $99 yo could get a 120 GB seagate drive (newegg's main page).
    I looked on Ebay and every 2 GB CF card I could find cost more then $100
    $85 for 2GB for something that will fail before some thing that can hold 80GB? Thats a bit pricey for me, especialy if it's to gain a possible 5 second reduction in boot time.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
  10. #20
    Maximum Bitrate Seraph's Avatar
    Jun 2003
    Elmhurst, Illinois
    I am with fluffy on this one.
    - Lwin M. Maung
    If it's stuck, force it. If it breaks it needed replacing anyway
  1. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 02:20 PM
  2. floppy drive and 6 in 1 memory card reader
    By cproaudio in forum General Hardware Discussion
    Last Post: 03-18-2003, 11:20 PM
  3. Iomega 340mb microdrive Compact Flash card for $68
    By pdpshaggy in forum Classified Archive
    Last Post: 05-11-2002, 03:31 AM
  4. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 12:24 PM
  5. Flash hard drive on ebay
    By Mp3 V in forum General Hardware Discussion
    Last Post: 02-16-2002, 11:39 AM
