Results 1 to 4 of 4
Thread: inputing into XM feature
    Nov 2003
    San Antonio
    Hey guys,
    I needed some help figuring something out. I am in the process of building a carputer for my G35 Coupe. I've seen Inor's setup and I want to do something similar to that. My car has a button for SAT input built into the factory Reciever, but I don't have a XM radio. I was wondering if I could somehow input my carputer audio output into the SAT input instead of a XM radio. This would be better then using one of those cassetes to input into the tape source. Thanks in advance.
    Jun 2003
    Chicago
    Quote Originally Posted by G35Pimp
    Hey guys,
    It depends if the SAT input is for the XM radio antenna for the audio.....what does the connector look like? It is looks like an RCA connector then it is most likely for audio, if it's an antenna connector then you are out of luck because that can only be used to recieve XM radio.
    Nov 2003
    San Antonio
    I know for a fact that it isn't a RCA connector. I've seen it and I don't know what you would call it but it was a rectangular connector made up of many wires.
    Sep 2003
    Wilkes Barre, Pa
    I doubt you will be able to then.. That connector is there to "control" a XM device.. There still might be an Audio connection there.. What ytou would need it to see if you can find the wiring diagram and see if there are any audio inputs.. Even then you would still need the PC interface to control you XM it would just play thru you car radio before going out to the speakers..
  1. The plan, diagram of planned setup. VGA, GPS, XM Radio, Laptop.
    By rally1 in forum General Hardware Discussion
    Last Post: 11-25-2003, 07:13 PM
  2. xm ready???
    By acornstu in forum General Hardware Discussion
    Last Post: 10-15-2003, 11:15 PM
  3. XM Radio PCR
    By [email protected] in forum General MP3Car Discussion
    Last Post: 08-08-2003, 12:01 PM
  4. sony xm radio
    By shaonuff in forum Classified Archive
    Last Post: 05-23-2002, 01:45 AM
  5. Dish sat receiver vs. XM receiver
    By jzgt in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:03 PM
