If you are going to use a laptop you can get a car adapter for it, no need for an inverter.
[H]4 Life
I'm a lesbian too.
I am for hire!
Ive got a generic adapter with adjustable amps and volts. eBay...19.99. I wired the Dell proprietary plug on to the adapter and it works great. I also wired a SPST switch inline between the power supply and the adapter. That way I can charge the unit whenever I'm in the car and not charge it when I get out.
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
I guess I was under the impression that i had to have a specific one for this impeticular laptop. you know with certain voltage and amps? not sure about that though. This is my first time dealing with a laptop, i build desktops.
Nope they're universal and fit almost anything. I have same one and its a steal at $20.Originally Posted by crzystng
Fabricator
I'm not sure how you interpreted what I wrote but I'll say it differently. I bought a generic power adapter from eBay. The power adapter had an adjustable output. I adjusted the output to match what the power adapter that came with my laptop said it output. In my case it was a dell that required 19 volts at 3.4 amps. I set the generic dc to dc power adapter to match and it worked like a charm. You can buy anyones power adapter, providing you have the proper plug on the end and providing you match the voltage and ampherage (sp). Check the power adapter that came with your laptop....on the side there will be specifications. If you know the model number, you can look it up on Dell's website.
Peter
thanks and sorry about the confusion there! LOL
got it now and shouldbe on my merry way! thanks for the help guys!
