Results 1 to 3 of 3
Thread: Opus remote option
    Constant Bitrate Lando's Avatar
    Apr 2002
    Opus remote option
    Quick question, I was thinking about ordering the new opus with the Remote trigger option, but I have one question first? If I use it to connect an amp, do I connect the 12v or the sensor wire
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    You will connect the red wire to the car battery the black wire is ground and the yellow is the remote. The remote can connect to the car radio or amp or the ignition switch.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
    Sep 2002
    Worcester, MA
    Look here. Thats the 90watt opus. The connector on the bottom is where you connect up the battery. Like inniss said, the red goes to positive, black to ground. The yellow is NOT however the remote. That is the wire that hooks up to the ignition wire so it turns on with the rest of the car. The top connector (not available on the non-remote trigger versions) is the remote trigger 'port'. It comes with another smaller wire harness with 3 wires. Two of them are useless, one is the remote trigger wire, which you would hook directly up to the remote trigger input on the amp. I have this set up right now in my car and it works flawlessly.
    hope that helps, there was a lot of confusion back when it was released as to which wire was the remote trigger, becuase some of the wireharnesses were not included.
  1. One reason not to buy the Opus
    By orangewhip in forum Power Supplies
    Last Post: 03-13-2004, 05:15 AM
  2. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  3. Replies: 13
    Last Post: 12-15-2003, 06:30 PM
  4. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 03:00 PM
  5. Cool remote option
    By bombboyer in forum General Hardware Discussion
    Last Post: 09-02-2002, 04:05 PM
