Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 802.11 software ?
    Jul 2002
    Houston, TX
    802.11 software ?
    I was wondering what kind of software solutions were available for 802.11b networks. I'd like to be able to manage wireless networks, wardrive, the works. I just havn't seen any third-party applications and hoped for you guys to expand my knowledge.
    Thanks!
    Constant Bitrate mindtool's Avatar
    Oct 2003
    Mesa, Arizona
    www.netstumbler.com allows you to pick up access points wherever you go and give you their ID type of make, etc..
    2006 Ford F-150 Lariat SuperCrew 5.4L
    StreetDeck
    Project: [■■■■■■■■■-] 90% complete (reconfiguration phase)
    Status report:
    -Configuring and wiring the camera system
    http://www.necevil.com/gallery/index...el=album&id=20
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    Netstumbler is the best wardriving program out there. Just remember that wardriving is legaly questionable, and accessing an open network is quite clearly illegal (Not that I think it should be).
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
    Jun 2003
    Memphis - TN
    thats what I use...
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    When are they gonna update netstumbler should be the question.
    It doesn't work with all 802.11b cards.
    Constant Bitrate SuperAJ's Avatar
    Aug 1999
    Quote Originally Posted by LESLIEx317537
    That is the only problem with netstumbler. If you decide to wardrive, make sure you look into building your own antenna. It can magnify your signal 10-100x from what I've heard, and they're cheap to build.
    Also, make sure you look into the different types of cards out there. I know that there are some cards that have removable antennas that allow you to attach pigtail connecters.
    The pigtail connectors attach to your antenna, and you will become a wardriving god.
    I wish I had more time to be able to wardrive
    Oct 2003
    Philly, PA
    which USB adaptors allow u to add an external antenna?
    Pontiac Grand Am
    building CarPC useing BookPC and Lilliput 7 inch TS.
    Jul 2003
    Fremont, CA
    Quote Originally Posted by djrkd
    This is answered in a CURRENTLY ACTIVE THREAD.
    Jul 2002
    Houston, TX
    Where can I find out how to build my own antenna? Does it just have to be in close proximity to the card, or somehow connect to it?
    On another subject:
    I wander between about 7 networks and it gets VERY annoying to have to go in and manually enter the IP and DNS for each one, as well as changing the SMTP servers in outlook. Are there any applications with which you can set up each network, then select from them wherever you go?
    P.S. I am using a PCMCIA 802.11b card. I believe it's a Microsoft MN-520.
    Thanks!
    Jan 2002
    Long Island, NY
    Dhcp
  1. GPS software
    By waylonh in forum Input Devices
    Last Post: 11-25-2003, 06:48 AM
  2. DDO software
    By Loftus in forum Software & Software Development
    Last Post: 04-01-2003, 10:26 AM
  3. List your software here!
    By PoBoy in forum Software & Software Development
    Last Post: 08-12-2002, 06:06 PM
  4. My numpad controlled custom MP3Car software - need your opinions
    By PorscheMP3 in forum Software & Software Development
    Last Post: 04-11-2002, 10:30 AM
  5. Shuting down software
    By Dimitris76 in forum Software & Software Development
    Last Post: 12-03-2000, 11:08 AM
