i have 40x4 lcd from timeline too. tell you the true, i have problem on connecting them. if you use the ribbon cable that come with the lcd module, make sure you reference the red cable is ground. and if you use the number that print on the PCB then the pin # is not respective to what it is.
as long as it is parallel alphanumeric character display with this pinsout number
pin12=vee
pin13=gnd
pin14=vdd
pin15=E2
etc...
you can just use the schematic from weise homepage
LinkBack URL
About LinkBacks
