Results 1 to 10 of 13
Thread: COLD problem ? rebooting
    Constant Bitrate BOND007BE's Avatar
    Jul 2003
    belgium
    Lightbulb COLD problem ? rebooting
    hello , when testing my carpc (jcp-alpha) in my car , i have some strange problems.
    When its cold , the PC boots , but halfway booting winxp it REBOOTS to BIOS
    after a try of about 5 times , pc works and stays working.
    i searched the forum , and i think its a matter of the HARDDISK.(maxtor)
    how can i be sure of it ? i thought when a harddisk fails it should be noted bij the BIOS , but bIOS isn't saying anything.
    any tips ?
    the sun always shine
    Nov 2003
    Colorado
    I have almost the exact same problem (takes 4 or 5 tries to get a good boot in cold weather). I'm sure that it is cold weather related because I do not have trouble in warm weather, and if I bring the computer inside overnight, it will boot first try in the morning. I too am using a Maxtor hard drive (80GB Maxtor D540X).
    Jul 2003
    belgium
    So , what possible solutions are there ?
    another OLDER harddisk , without liquid bearing ?
    but how can i be sure wich disk is gonna work ?
    i now have another problem to
    I use a second bat 12V 7 AH , with diode , works fine , i can start the engine and nothing appends to the PC (no reboot or so) , but when ex. using windshieldwipers , the PC gets a reset , also when activating the up and down buttons for the glass in the door i get a reset.
    so i quess thats because when activating the things , i get NOISE on the POWER , anough to reset my pC .
    anyone know how to filter this out ?
    greetings
    Variable Bitrate Mikesz's Avatar
    Apr 2001
    not really a fix, but a warning. I had this problem with my maxtor drive. Eventually, the drive failed.
    I have since switched to a wd 7200rpm drive. It still wont boot in the cold though. I get a drive not found error. But I have had no restarts or loss of data. After the second restart the drive is recognized and boots. The system runs slow though for the first 5 minutes, im not sure if this is caused by the drive, but I would guess it is.
    mike
    91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
    Maximum Bitrate none's Avatar
    Sep 2003
    Quote Originally Posted by BOND007BE
    Not an older harddisk, just one without Maxtor's "Fluid Dynamic Bearings"
    greetings
    I don't think it's a noise problem, I imagine it is more a voltage drop issue. You need to double check your diode wiring and make sure that the secondary battery is properly connected.
    Raw Wave
    Jun 2003
    How cold are you running the HDD?
    A western digital caviar SE for example recommend an operating temp a round 5 - 55 deg C.
    If you start the PC at -20 deg C then I dont think you gonna have much luck.
    Jul 2003
    belgium
    i first gonna connect a temp sensor to the disk to check what temp the disk is,
    but i think its gonna be -5 -10 degrees
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    I have an old maxtor 8.4 that has a small ammount of bearing noise in very cold temps. But no data loss or any other failures in multiple years of use in Denver. Cold in the Winter and occasionally very cold over night temps.
    TruckinMP3
    Read the FAQ!
    Nov 2003
    Colorado
    My 80G Maxtor does not have fluid bearings, but still has troubles in cold weather. I have read most of the "cold weather" threads in this forum and it seems that people who do not have problems in cold are using older hard drives. Unfortunately, it's hard to find an older hard drive with a large enough capacity (I have an old 8GB Maxtor lying around, but it can hardly handle my 70GB MP3 collection). It's also hard to find a new drive that does not have some kind of "quiet" technology (i.e. fluid bearings), and runs at 5400 RPM (lower power consumption for EPIA based computers).
    Jul 2003
    belgium
    what about setting the SYSTEM to old disk ex 3gig and data to new disc
    and place the old disk beneath the newdisk so old disk heat up newdisk.
    SYSTEM should always start i guess , only playing directly will give some problems i think
    what do you guys think
  1. psone screen video problem
    By WILD9 in forum ME Archive
    Last Post: 11-27-2003, 01:38 AM
  2. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
  3. Replies: 8
    Last Post: 12-31-2002, 12:37 PM
  4. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
  5. Heating problem
    By Viktor Cheung in forum General Hardware Discussion
    Last Post: 01-17-2000, 07:45 AM
