The datasheets for the 7812 says it has a dropout voltage of 2.0V and requires a minimum of 14.5V input to regulate. Did you measure the output voltage of the 7812 under load ? It might be much lower than 12V.
If so, you might want to use a LM2940-12 or similar low dropout (0.5V) regulator.
LinkBack URL
About LinkBacks
!!!!, I ended up removing the 7812 regulator (did not read the fine print on required voltage input, that's what you get for that) and powering the LCD directly of the battery. I did keep the relay, so now when I turn on the system after x amount of time the LCD comes on when ITPS triggers the relay, and stays on for the 35 sec or so once I power down. I did conclude that the 70W-A can not survive the crank, but what the hell another project to work on......
