Results 11 to 20 of 30
Thread: Cold Weather Hard Drive
  1. #11
    Constant Bitrate BOND007BE's Avatar
    Jul 2003
    belgium
    ok thats an option , but i have to ALWAYS open the trunk to put the disk in it
    so not very friendly option i think
    the sun always shine
  2. #12
    Dec 2003
    hi again
    no see i was going to mount the disk cradle in the center armrest.
    with a usb extender. so the computer can be in the back
    hope that helps
    Victoria
  3. #13
    Apr 2001
    NJ, USA
    I've never had a problem with my Western Digitals in NJ winters. Only thing that didn't wanna work was the PSU but only when it was under 30F. After the truck warms up she'll start fine.
    P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
  4. #14
    Nov 2003
    Colorado
    Update:
    For the last 2 days I have been trying a Seagate Barracuda drive in my CarPC. In its specs, Seagate lists 0C - 60C as the operating temperature (5 degrees lower that most other hard drives). They also claim it can withstand more G's of shock that other drives.
    Anyway, to make a long story short, it was fairly cold last night, and the PC didn't startup any better than it did with the maxtor drive. I'm starting to wonder if its really the power supply (PW-60) or RAM (Kingston Value RAM) that doesn't like the cold.
  5. #15
    Maximum Bitrate tom2112's Avatar
    Nov 2003
    Sharon, PA
    Quote Originally Posted by sigma957
    Update:
    RAM likes cold. So do processors and chipsets. It's the nature of integrated circuits to like cold. It's the stuff with moving parts that you've got to worry about.
    So far:
    M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
  6. #16
    Jul 2003
    belgium
    i put a temp sensor on ly harddisk , and it realy likes +5degrees celisius, below it doesnt like it much.
    what about a heating system ?
  7. #17
    Apr 2003
    Canada
    Well with any electronics you want to warm them up before using them. Failure to do this will cause lots of thermal contraction and expansion which will eventually decrease the life of your hardware or just wreck it if it wasn't designed to accept below opperating values. Which technically nothing is
  8. #18
    Dec 2003
    Germany
    Since it got below freezing around where I live I ran into the problem that the HDD sometimes won't start until it got a little bit warmer inside the car.
    That is why I took a old Peltier that I used to use for overclocking the CPU and attacked it to the HDD. It gets warm quite fast and I can start the PC about 30 secs after I turned on the Peltier. It is a bit dangerous though, because if you forget to turn it of there is a chance you fry your HDD. That is why I am currently soldering up a timing device that turns off the Peltier after 90 secs.
    Jeeve5
  9. #19
    Jul 2003
    belgium
    cool do you have pics ?
  10. #20
    Dec 2003
    Germany
    Nope, unfortunately not since I don't have a Digital Camera, yet. Maybe after Christmas
    Jeeve5
  1. Cold hard drive fluid bearing data loss
    By Mikesz in forum General Hardware Discussion
    Last Post: 12-13-2003, 08:17 PM
  2. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 03:20 PM
  3. How does a hard drive just die?
    By Sleeka in forum General Hardware Discussion
    Last Post: 08-08-2002, 03:27 PM
  4. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:24 PM
  5. hard drive failure in cold temps
    By mg6134 in forum General Hardware Discussion
    Last Post: 02-14-2002, 04:56 PM
