Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Cold Weather Hard Drive
    Nov 2003
    Colorado
    There have been several discussions in these forums about cold weather causing problems with hard drives. I have not seen a definitive answer as to what brand/model is known to work best in cold temperatures. My drive is an 80GB Maxtor D540X (5400 RPM, no FDB), and it does not seem to like temperatures below freezing. If anyone is having success in cold temperatures, could you please post the brand and model of your hard drive?
    Constant Bitrate parawing742's Avatar
    Jun 2003
    Tennessee
    Quote Originally Posted by sigma957
    Hitachi (www.hgst.com) is making a drive called the Endurastar which they say will work from -20C to +85C. The only problem is that it only comes as a 20GB unit. Probably expensive too.
    Phillip Hullquist
    I entertain people through adventure movies.
    www.11visions.com
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Maxtor 8.4.... old and in use in the truck for over 3 years...
    TruckinMP3
    Read the FAQ!
    Constant Bitrate BOND007BE's Avatar
    Jul 2003
    belgium
    what about laptop disks ? what degrees do they work
    the sun always shine
    Nov 2003
    Colorado
    Quote Originally Posted by BOND007BE
    I checked the specs of a few laptop drives, and their operating temperatures were 5C - 55C (same as most desktop drives).
    Jul 2003
    belgium
    mm not a solution i guess
    what about a heating system ?
    because sometimes (in the winter its gonna freeze)
    Nov 2003
    you could always get a remote start that warms the car when the temperature reaches a certain temperature so the interior is always heated. Aside from keeping the computer warm your car will be nice and toasty when you hop in :-D
    Jul 2003
    belgium
    not always an option i think.
    compact flash 20 GIG doesn't excist i quess ????
    Dec 2003
    Hi
    My idea for my carputer HD is to use a usb2.0 external cradle
    an use a quick release method for the cradle...that way when
    its cold like it is in MN... I can remove the cradle with the HD in it.
    just like a removeable face plate
    just an idea
    Victoria
    Nov 2003
    stop taking my ideas!
  1. Cold hard drive fluid bearing data loss
    By Mikesz in forum General Hardware Discussion
    Last Post: 12-13-2003, 08:17 PM
  2. All-electronic flash drive and solid state hard drive
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 12-12-2003, 03:20 PM
  3. How does a hard drive just die?
    By Sleeka in forum General Hardware Discussion
    Last Post: 08-08-2002, 03:27 PM
  4. External notebook hard drive help
    By mtmsol in forum General Hardware Discussion
    Last Post: 04-18-2002, 01:24 PM
  5. hard drive failure in cold temps
    By mg6134 in forum General Hardware Discussion
    Last Post: 02-14-2002, 04:56 PM
