Results 1 to 10 of 18
Thread: why do i have to push the power button after shutdown?
    Constant Bitrate kalito's Avatar
    Nov 2003
    ny
    Question why do i have to push the power button after shutdown?
    I upgreated my laptop to xp profecioanl and now evry time i select shut down , it gives me a message "now it is sve to power off you system" but before it didn't do that. it will just shut off...completally.. and on my pc i also have win xp pro. and i don;t have to push the power button after i've selected shutdown... how can i get rid of the option (problem for me) in my lap top
    Dec 2003
    try installing a fresh copy of winxp without upgrading. i built alot of computers and never had that problem...only when i upgrade the operating system to xp.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by kalito
    Try this - support.microsoft
    Nov 2003
    ny
    Quote Originally Posted by thanhnguyen510
    o no i formatted my HHD and then i intalled the xp pro. that's when i started geting the massage .. i remember i used to do that in an old pc i had with win95
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    That's usually a thing with AT motherboards, that would be why it happened on your old pc. Is your new pc AT? or ATX?
    Nov 2003
    ny
    Quote Originally Posted by Pudge
    i don't know what at or atx is? and b/4 i had xp home and it did happend then.. and even when i had winME. why now? how can get rid of that...
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    A simple way to check if your board is AT or ATX is to check the cable from the power supply to your motherboard. Here is a side by side comparison http://www.buildyourown.org.uk/build.asp?sect=6&page=6
    cvi
    cvi is offline
    Feb 2002
    DK
    Pudge: Its a laptop.
    Kalito: check bios settings and windows power management config. And check the link laidback posted to microsoft knowledgebase.
    Raw Wave
    Jun 2003
    You should see Advanced Configuration and Power Interface (ACPI) PC on your device manager, make sure its enable and no conflict.
    Check the power management in control panel and your BIOS make sure its all looking OK.
    You BIOS should support it since it has worked before
    Nov 2003
    ny
    at the boot up menu?
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 04:53 AM
  2. Rewiring ATX power button
    By DCC in forum Power Supplies
    Last Post: 02-07-2008, 05:17 AM
  3. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 09:15 PM
  4. Routing power button to front of PC. Can wire be too thick of gauge?
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 09-27-2003, 02:32 PM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 02:36 AM
