I want to use the Monsoon amp/speakers until I can afford to buy new ones. Is there a way to tie into the Monsoon amp without using a headunit or will I just need to wait until I have more $$?
Ok, there is a lot of information on using amps with the output of your carputer, I have never done it but my understanding is that you just use your sound out of your PC to your amp using the RCA cables, so yes there is a way. You could always use a FM modulator or something to that matter and tune your headunit in with that, or if your monsoon setup has aux input use that
LinkBack URL
About LinkBacks
ed but the only Monsoon systems that come up are on VWs.
