Results 1 to 9 of 9
Thread: where to get 12v from laptop
    Constant Bitrate kalito's Avatar
    Nov 2003
    ny
    Question where to get 12v from laptop
    i got a touchscreen from m3 (it connectd to serial) but i thoght i was going to be a eazy task but i need to get 12v to power it , i tried getting it fron the lcd backlightpower sourse but there isn't enough power fro both.. so the next thing is getting the power from some where else any idea....screen sourse... mouse sourse... i have no idea... can anyone help me
    Jun 2002
    Quote Originally Posted by kalito
    I wouldn't recommend using a laptop to get the power. They aren't meant to provide that much power. You can buy a regulated 12v dc adapter from Radio Shack and that would do the job. It's tough to find a good 12v source on a laptop because the components usually use 5v. A serial port can provide 12v but it won't be enough to power an lcd screen.
    Tom
    1993 Probe GT
    Rio Car w/20gb
    Nov 2003
    ny
    Angry
    Quote Originally Posted by tbdombrosky
    Tom
    is like add on kit but the guy the sold me the kit did not specify the it need it more than just connecting to the serial port ... i didn't use the usb option because i only have 2 and i need then both so is was eather getting a usb hub or get the a serial touch kit... so i wnt with the serial... so i'm just better of getting the adapter from radioshack... this is the kit the 13.3 kitfrom http://www.touchwindow.com/miva/merc...egory_Code=OEM or retuning the produck and getting a universal kit... but the universal comes standar for 12.1 to 14 screens and i don't want it to look dump...
    Jun 2002
    Wait, are you talking about powering it or just connecting it to the computer?
    Tom
    1993 Probe GT
    Rio Car w/20gb
    Nov 2003
    ny
    ot connects to serial but it need 8-15v to run... and don't want to use any unnessesary or extra connector...
    Jun 2002
    Oh, so you're just trying to power the touchscreen and not the monitor. Sorry, I misunderstood you earlier. Most touchscreen interaces are powered by the serial or usb port automatically. If that doesn't work then you can just wire it directly to the car battery. 8-15 volts is a wide range so you should be fine. Just make sure that you have a fuse on there.
    1993 Probe GT
    Rio Car w/20gb
    Nov 2003
    ny
    which is dc and ac because right now is working on a 9v dc...
    Dec 2002
    Chico, Ca
    Don't forget to fuse that thing if you wire it directly to the battery
    Nov 2003
    ny
    which is dc and wich is ac and which uses in a car the dc or ac..?
  1. Simulating laptop functions
    By corsamel in forum Software & Software Development
    Last Post: 05-20-2004, 02:41 PM
  2. Replies: 11
    Last Post: 12-02-2003, 07:29 AM
  3. any 12V sources inside laptop?
    By dimas in forum Power Supplies
    Last Post: 11-23-2003, 12:52 PM
  4. Possible Solution for Dual Sproggy 12V @ 10A
    By mp3z24 in forum Power Supplies
    Last Post: 07-10-2003, 12:33 PM
  5. Ahh help laptop boot?
    By adrian_uk17 in forum Power Supplies
    Last Post: 06-05-2003, 03:01 AM
