Results 11 to 20 of 25
Thread: Best mountable, DC powered USB Hubs?
  1. #11
    Constant Bitrate RX7FDTT's Avatar
    Dec 2003
    If you look closely, the Picture shows the power adapter just to the left of the USB Square Uplink Connector...
  2. #12
    Dec 2003
    Will this work, it sais it's powered via the USB Hub and has per port overload protection, but I wonder weather that hub would support say 4 Mobile USB2.0 DVD ROM drives... (Powered off the USB Port) Not that I need that many but as far as power draw goes I wonder .... :scratch:
    http://cgi.ebay.com/ws/eBayISAPI.dll...31495&tc=photo
    Than again for under $10 ... we'll see... And there's other auctions for that price too
  3. #13
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    I have a GE usb hub I'm selling, it works off 5v at 2.1A.. and I hooked it up to work with a psu directly
    FS: carputer parting
    Mine needs to be updated.
  4. #14
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    Not directly related but I purchased on of these cables
    http://linitx.com/shop/product_info.php/products_id/323
    Its converts the mini-usb connector for the 3rd and 4th USB ports on the Epia MB into a normal MB connector. Its works a treat with the front connectors on the 3688 case I have meaning that I've now got 4 usb sockets all able to give out the full 500ma.
  5. #15
    Mar 2007
    Re: Best mountable, DC powered USB Hubs?
    Hubs designed for 10-28V DC connection and mobile deployment:
    Digi Hubport - Industrial USB Hub with 4 or 7 Ports
    --Jim
  6. #16
    Feb 2006
    92 bucks, haha, digi port no thanks. i got one from my work at circuit city, its just a kensington K33141 for like 30 bucks. 4 port usb, with a front cover that comes off with screws. I plan on using that in the dash, where my ashtray is in my passat, as well as mounting a couple other connector like a 1/8" audio-mini connector.
    What i really like about this model is that the DC plug connection is right on the back of the unit. And this, unlike some other basic models sold in retail stores, this one comes with the ac/dc power supply. That way i can take power connector right out from behind the dash.
    i don't have it where i am right now, im gonna double check for you, but i am pretty damn sure that it was 5 Volts.
    this is the unit PocketHub USB 2.0
  7. #17
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I know this is an old thread but I have been looking for something similar and came a cross this:
    http://www.ultraproducts.com/product...&productID=469
    I like the idea of having an audio input as well.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  8. #18
    Dec 2007
    Miami
    I was just looking at them before comming back to the forums to ask questions..lol.. so heres my question.. with the one call DIGI PORT.. do you think I would be able to hook that up to my 12v power (ciggy lighter spot) or what should I use?
  9. #19
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    I'm looking to add a usb hub too, but too lazy to build a regulator so Id rather run it off the +5v or ideally the +12v from my psu. ebay has some 4 port powered hubs for under $15 shipped.
  10. #20
    May 2008
    Looking for 12 volt DC powered...
    So, it seems like someone could make a fortune selling a cheap 12 volt - 5 volt converter and a usb hub and making it all one box...
    I am thinking of using one of those 12 volt - XX volt converters, and then plugging that into a hub, but that seems like such a crummy solution. But would cost me under 14 bucks..
    Is Digi really the only provider of a 12 volt powered USB hub???
    Eric
  1. USB Hubs / Powered or not
    By Scafremon in forum General Hardware Discussion
    Last Post: 06-15-2006, 09:03 PM
  2. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 03:44 PM
  3. Keep USB Powered to keep GPS alive
    By MeanGT in forum GPS
    Last Post: 12-02-2003, 11:54 PM
  4. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
