Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Best mountable, DC powered USB Hubs?
    Nov 2003
    I have an EPIA board and it only has two USB ports and with the ever expanding number of peripherals hooked into my computer I am in serious need of some USB Hubs. Several of my devices (USB HDD, USB 802.11b adapter, etc.) take up pretty much all the power that a single USB port can supply, so hubs that get their power from the USB port are not an option. I also am running off DC, so wall-wart powered hubs are not an option. I have managed to power several peripheral devices that would ordinarily run off bricks by using the +5 and +12 volt lines of the molex connectors coming off my power supply. Both of the USB hubs I have tried require unusual voltages (7.5 volts). So, anyone have any ideas on how I can get some powered USB hubs to work in my car? I would ideally like something that can easily be mounted.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I have a USB2 hub which IIRC said it needed 6V. I hooked it up to my 5V from the PSU, and it is working, powering a USB GPS, and a USB2 to IDE adapter for my slimline CDROM drive
    Check for some more USB hubs, there are some out there that run off 5ish volts
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    I bought one off newegg that use 5v, but 2.4A!
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    off the shelf at comp USA I got a usb 2/1 that runs off of 5v DC. 1 inch square of velcro and dazam! 4 more usb ports.
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    Nov 2003
    Yes, I know that there must be some out there that work, but saying so doesn't help me any. If you have something that works reliably off the 5 of 12 volt lines of a molex connector, could I please get some brand/model numbers. I don't want to just go around buying USB hubs until I find one that works.
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    This is what I bought, works perfectly off my 5V line: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3054173165 . It has four hi-speed ports and is the smallest powered hub I could find for cheap. They are now 3M stuck in my glove box. Just search ebay for "Mini USB 2.0 HUB" and you'll find a lot.
    I didn't know that they even made 7.5V hubs, that's is rediculous in my opinion. It must be regulated internally to 5V.
    Constant Bitrate RX7FDTT's Avatar
    Dec 2003
    Have you guys checked this out ?? Seems like a cool idea, and with a little ingenuety you'd be able to mount or modify it not to expose the guts...
    http://www.siig.com/product.asp?part...20-%20Internal
    it seems to take power from a floppy drive power hookup...
    Dec 2003
    Massachusetts, US
    thanks for the link. I wouldn't be suprised if closer inspection of that board reveals it to be using just the 5v or 12v... both good for what we're talking about :-)
    Nov 2003
    I really like the looks of that one from siig, particularly that it takes a floppy connector. I think I saw one like that at Fry's once, so I will check there in the next few days.
  1. USB Hubs / Powered or not
    By Scafremon in forum General Hardware Discussion
    Last Post: 06-15-2006, 09:03 PM
  2. OPUS 150 watt, USB stays powered???
    By GScherler in forum Power Supplies
    Last Post: 12-19-2003, 03:44 PM
  3. Keep USB Powered to keep GPS alive
    By MeanGT in forum GPS
    Last Post: 12-02-2003, 11:54 PM
  4. USB Sound and Bus powered hub
    By Suprapc in forum General Hardware Discussion
    Last Post: 04-21-2003, 04:21 PM
  5. USB Sound Card with ASIO driver and volume control
    By tbdombrosky in forum General Hardware Discussion
    Last Post: 02-04-2003, 12:00 AM
