I will add this functionality to FrodoPlayer as well.
cool no problem, icon is fine. I got enough candy on my desktop anywayOriginally Posted by frodobaggins
plus if i ever wanted to change the icon i could just make a shortcut to it, and change the icon of the shortcut.
[H]4 Life
I'm a lesbian too.
I am for hire!
Does anyone know of a hardware line killer? With a momentary switch to toggle it? I really need something like that.. I could make it if someone had diagrams and whatnot to how to make it![]()
1993 BMW 325is - 15.2sec
You could just cut the input wire and put in a push button switch on the ground wire, right?Originally Posted by SiGmA_X
What ? I don't understand ?
[H]4 Life
I'm a lesbian too.
I am for hire!
cut the input wire, there is red, white and a ground inside. Connect the reds and whites, and connect the grounds on either side of a switch...
yeah, simply disconnecting the ground will kill everything, as all of those systems use a common ground.
car computer rev 5: 8" lilliput and usual suspects
So in my RCA cable, which wires do I want to split? I have a 4 relay setup that creates a toggled switch out of a momentary pulse.
