Shamir,
Sounds like your Bose amp is a 4 channel amp, not 5 channel. If you are going to drive your center (5th) channel AS A SEPERATE SURROUND CHANNEL, you'll need a seperate amp channel to do it, just like you are doing with your amp/sub. However, if all you want to do is "simulate" a center channel (ie, not deliver what is actually recorded in the center channel on your source DVD), you COULD implement some sort of bridge. I would be surprised if there are not some of these products in the auto-audio aftermarket. Again, bridging LR & RF will NOT give you TRUE 5.1 surround.
You are correct. You don't want to connect your LF & RF wires together, for several reasons, the least of which is losing stereo seperation. It could blow you amp!
That being said.....do you really NEED 5.1? What will be your Dolby/DTS source (DVD,XMR)? You are correct, most of the vocals in DVD's come from the front channel, but I would bet most of what you will be listening to is MP3
music, which is NOT 5.1 surround. I believe the EPIA can give your some sort of DSP simulated surround, which would
sound OK without a seperate center channel.
I would also encourage you to look into how the EPIA handles NON-5.1 surround sound (ie standard stereo MP3s) when the speakers are connected as you intend (5.1). You may be juggling the mixer controls each time you switch audio sources from MP3 to DVD....not a big deal, but not real desirable either.
