Have you tried grounding EVERYTHING (HU, computer, amp) to the same point?
As by hooking the sound into the amp directly got rid of the noise, there is a ground loop between the HU and the carputer/amp.
By grounding all my equipment to the same point, I was able to remove all the noise when I used a HU. Or, you could just try a wire from the casing of the HU to the ground for the amp/carputer
Garry
LinkBack URL
About LinkBacks
