Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Basic electronics question...
  1. #11
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    yea it can
    it could be done for you...
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
  2. #12
    Dec 2002
    NoCal
    http://superbrightleds.com/
    As the name implies, they have very bright LEDs
    --Dima
  3. #13
    Variable Bitrate Sh0cker's Avatar
    Aug 2003
    LI, NY
    since we are talking about LEDs here, i need some help locating online store that carries 3mm Red(high bright) 12V LEDs.
    thx
    Danny.
    "If today was perfect, there would be no need for tomorrow."
    My Car Project® ‹== !10.4" Allbrite, touchscreen, epia, 150opus, gps, wireless, sony remote [old] 128x64 Crystalfontz +double din [new]
  4. #14
    cvi
    cvi is offline
    Feb 2002
    DK
    Sorry, i wont speak up again. BUT...
    * He needs more leds connected. (read post)
    * He asked for a 3 Volt resistor.
    Since there are no such thing, the easiest to do are leds in serial. Power coming from the computer psu would give 5V, that makes 2,5 V for each led.
    * He dont have to mess with calculators or make a fool of himself asking for a 3 Volt resistor.
    * It will work.
  5. #15
    Dec 2003
    Michigan
    Quote Originally Posted by cvi
    * It will work.
    I'm sorry to say, it won't work. An LED when conducting does not drop 2.5 volts. LEDs are misleading. They are CURRENT SPECIFIC not Voltage specific. The resistors aren't really used to reduce the voltage, they are used to limit the current. An LED will operate just fine with only 0.7 volts applied. The Spec on the LED of 3V is a MAX operating voltage, not a voltage requirement. Use the reistors. Or, if you wish, some LEDs are "pre-resistorized" to run TTL (5V) levels without an external resistor.
    2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
  6. #16
    Low Bitrate crosseye's Avatar
    Dec 2003
    Syracuse, NY
    CVI, just for your future reference, I tried hooking two LEDs in series up to a 5V DC power supply. Both LEDs were lit but got REALLY hot REALLY fast. I took them off before they blew. With a single 22ohm resistor in series with 1 LED, no heat could be noticed by touching the LED.
    Speaking of the "pre-resistorized" LEDs, I have like 6 of them here that i do not need. They are red and supposed to work with 5V. I don't have the packaging anymore so I don't know the exact brightness, etc. They look pretty bright with 5V applied to the terminals.
    If you were looking for an easy way to impliment LEDs with 5V, I can sell these to you for like $0.50 a piece plus another $0.50 for packaging and shipping. You don't need to worry about a resistor with these puppies, just apply a 5V difference to the terminals and you're good to go.
    Email me at [email protected] if interested.
  7. #17
    Raw Wave
    Jun 2003
    Thats not true.
    You need 2V to operate an LED, depending on colour...you need to let it conduct first before it can even light up. The 2-3V is the forward voltage and not maximum operating voltage...thats the voltage it need before it operates.
    Just for the record I just stick a 1.5V on a green LED and nothing.
  1. Your basic newbie question here.
    By tlbuckingham in forum General Hardware Discussion
    Last Post: 09-16-2002, 01:42 AM
  2. Electronics question
    By SuperMatty in forum Off Topic
    Last Post: 08-11-2002, 02:47 PM
  3. lcd power question
    By jrbless in forum LCD/Display
    Last Post: 04-07-2002, 12:27 PM
  4. Do you work in te field of electronics???
    By THEMP3KID in forum Off Topic
    Last Post: 02-12-2002, 09:02 AM
  5. Another inverter question...for electronics gurus
    By moahdib in forum Power Supplies
    Last Post: 06-07-2001, 08:30 PM
