Results 1 to 10 of 13
Thread: Help! I think I have a bad Mini-ITX!
    Oct 2003
    Well I got all ready to install the thing last night and got everything hooked up and started it up. OK, the power supply powers up and the fan on the CPU starts spinning, and...that's it. Nothing else happens...no monitor activity or anything. I figured it might be the ram, though I thought I got the right kind (PC2100 DDR 266MHz), so I switched it out with another stick of 256 that is also 2100 DDR 266...still nothing. Am I doing something wrong or do I have a bad board? Any ideas or things to try?
    Thanks,
    Dan
    Nov 2003
    Marietta, GA
    Why don't you give us a little detail about your system. (mobo, ps, case, monitor, etc).
    MikeH
    Oct 2003
    Well, it isn't much of a system yet. I was trying to power it up for the first time to make sure everything works. No case, 250w power supply from an old gateway, and a gateway monitor.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Which itx board?
    Did you already have it working?
    if so...what has changed?
    Does it provide a beep code?
    any led activity?
    ect....
    2005 Ford Focus ST
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    I had the same problem as you. I had tyo RMA my board back to the shop.
    Oct 2003
    OK heres an update...I've been playing around with it for a little while. No devices will power up (CDrom, hd etc) unless nothing is connected to the IDE cables. If nothing is connected, the drives spin up fine, but I still get nothing on the screen. I think this thing is shot..
    Dec 2003
    You might try checking to see if your IDE cables are hooked up correctly. On my old system if the cables were backwards it would act like that.
    Low Bitrate pc832's Avatar
    Nov 2003
    San Diego
    Unhappy Me Too
    I also had tons of issues with my Mini-ITX. (m10000 to be exact) I finally went the RMA route....bummer. I'm still waiting for the replacement.
    You can read about my ordeal HERE
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I dont know if the itx boards have a cmos clear jumper but if it's set to clear the unit wont power on and the drives wont spin up when connected
    Variable Bitrate NJay's Avatar
    Mar 2003
    UK
    I get this alot with my Eden Epia 800.
    If you attach a IDE cable and no drives or the wrong way around, it just spins up the cpu fan and that's about it. No beep codes, nothing.
    I found the only way to get it to reset is to disconnect the ATX cable, wait about a minute and then plug the ATX cable back in. Works fine after that.
  1. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  2. Opus and Casetronics C-134 Mini ITX
    By millec in forum General Hardware Discussion
    Last Post: 06-24-2003, 01:31 AM
  3. Xenarc with Mini Itx and Powerstrip
    By Glyn in forum LCD/Display
    Last Post: 09-24-2002, 10:26 AM
  4. mini itx and xp
    By oddcomp in forum General Hardware Discussion
    Last Post: 09-16-2002, 04:20 PM
  5. Mini ITX With 370 Socket
    By marauderz in forum General Hardware Discussion
    Last Post: 07-10-2002, 12:04 AM
