Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Additional ide?
  1. #11
    Jul 2003
    Earth
    Ide drives are so cheap now that i think id rather stick with them......maybe a Raid controller?
    If i got a Raid controller but then decided i didnt want to RAID in anyway can i turn the functons off and just use it as a ide controller.
  2. #12
    Jul 2003
    Earth
    Lcd issue...
    Oh is anyone good with LCD's?
    Power to lcd?
  3. #13
    Maximum Bitrate churnopol's Avatar
    Apr 2003
    Delaware!!!
    directron.com has their own brand of controllers starting at $16, scsi, sata, ata. oh these are just your basic 32bit 2 channel controllers.
    What do you need a zip100 drive for?
    To make things easier, think about getting a cd duplicator with firewire ports.
    Falcon cr53 w/ via epia m10000. Nokia 3650 blutooth phone.
    Better than winamp. Click here for qcd player.
  4. #14
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    I picked up an ATA133 RAID controller based on the Silicon Image 680 chipset for 20 from Maplin.
    It works for hdds in RAID 0/1/0+1, JBOD, as single drives (no RAID type) and also will do ATAPI devices (cdrom etc), which some controller cards won't do
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
  5. #15
    Jul 2003
    Earth
    Oh your not wrong!! i can see it on the webby......might just pop down and get one!!
    that would give me another 4 devices..is the controller good i though raid cards were normally 70 squid;..
    cheers
  6. #16
    Aug 2003
    Essex, England
    I'e been using it since April with 2x 80GB 7200rpm 8mb drives with no problems at all
    This is a "software" RAID controller, which means it uses the host CPU for it's RAID calculations. However, with the speed of CPUs nowadays, this is less of an issue for software raid cards, but of course, hardware raid cards are slighly faster, and therefore more expensive
    Garry
    www.aimee.cc
  7. #17
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    if you want a hardware raid controller checkout 3ware. Adaptec also makes one, but it's not near as cool as the 3ware setup. I've got two 64 bit 4 drive 3wares (don't worry, not in one computer). One of them is simply running a CD drive and 2 harddrive raid- so you don't have to use them exclusively for RAID.
    car computer rev 5: 8" lilliput and usual suspects
  1. convert ide to sata. Will it work for cd/dvd's?
    By churnopol in forum General Hardware Discussion
    Last Post: 08-12-2005, 05:53 PM
  2. WTB: Laptop dvd drive to ide adapter
    By leenas in forum Classified Archive
    Last Post: 06-30-2003, 09:04 PM
  3. FS: 15' IDE Cable
    By nolmscheid in forum Classified Archive
    Last Post: 03-18-2002, 04:30 PM
  4. Cat6 cable -> IDE Cable
    By dan0myte in forum General Hardware Discussion
    Last Post: 08-31-2001, 09:29 AM
  5. Long IDE cables
    Last Post: 03-16-2001, 06:37 PM
