Results 1 to 6 of 6
Thread: LCD hookup
    Feb 2001
    Post LCD hookup
    Hello all,
    I just a nice big char LCD panel, and am trying to hook it up.
    It's an AND711AST-30 LCD panel that is using a Toshiba T6963C controller.
    I think I have the pinout hooked up correctly to the parallel cable, but there is also two regular wires (white and black) on the opposite side of the panel. I'm not sure what these do. Any ideas?
    My main question is, I assume that this thing needs power (it's not getting it through the parallel port is it?) So do I just hook up a 5V and ground directly to the correct wires on the ribbon cable that I have going from the panel to the parallel plug?
    Thanks for any tips!
    John C.
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Post
    Idono about the power part, you should be suplying +5 somewhere.... ground it can pull from the interface.
    the 2 random wires are probably for the backlight <just a guess>
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
    Feb 2001
    Post
    Ya the two wires are almost definetly for the power for the backlite.....one needs + 5 and the other i thinik gnd or negative 5, but they shuld be labeled A and C anode and cathode....anode is negative, and cathode is positive if i remember right, just try it one way if it doesn't work that way change em, try before you solder btw mine was backwords....
    Player: Custom Plexi-glass case, k6-2 500 MHz Proccessor, 250W power supply 13.1 GB removeable HD, 4x20 INVERTED LCD, Voice Control Compliments of TrimodalVoice, IRman, Keypad buttons on LCD
    Car: 1983 Chevy El Camino Conquista, KICKIN CAR!
    Feb 2001
    Post
    Thanks for the tips all. I've got some juice running to it now, but it still won't fire up. I think I need to do a reset, etc....and bring it up properly in a program.
    Here is the datasheet for this LCD.
    http://www.purdyelectronics.com/PDF/AND711.PDF
    Now on the second page, there's the example of a variable negative voltage supply. It seems as though this is for contrast control. I also assume that this is necessary to get this thing working. Could someone give me some tips on the schematic on page 2? Does anyone have a good site to learn how to read schematics?
    Thanks!
    JC
    Aug 1999
    Yorba Linda, CA
    Exclamation
    FYI: Anode is Positive (+) and Cathode is negative (GND). Don't hook it between +5 and -5... this is actually 10V and will burn out the backlight if it doesn't have current limiting resistors in it.
    Jason Johnson
    Yorba Linda, California
    http://www.m2pc.com
    M²PC Phase IV - *** PENDING ***
    Feb 2001
    Post
    the backlight might be 120V. Mine is. It's similar to the light's on watches, it's not an led. I just made 2 leads, and wired it up to a wall socket.
