GPS readible on 960(H)x234(V) units?
It seems that 640x480 is recommended for GPS, but how good are the units that do 960(H)x234(V) for GPS? Basically is 640x480 fully readible on these regular video units? Planning on using Delorme GPS setup...
if u plan on using a that system, u might want to stick with a 640 x 480, it will be much easier to read the text. and it will also look a little neater at that resolution
Not sure if this is helpful but I remember reading a post from lifter that said:
"Something you should know about video LCD's- it doesn't matter what the resolution is since NTSC is only 525 lines, with only 475 viewable."
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
