Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Running remote signal to amp from parallell or serial port?
  1. #11
    Jan 2004
    Yes, onboard sound.. As of now, my amp is also powered by the same relay as the PC.. Looking into the DTR-link Confused gave me, though...
  2. #12
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    If you're still getting the start up beep on an EPIA, it's probably time to check for an updated driver pack or BIOS. This was a problem with the EPIA 800 originally, but an update saw it fixed.
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
  3. #13
    Jan 2004
    I did what Windows Service that raises DTR on powerup said, and it works like a charm! PLUS, I don't get the annoying sound when machine is cut off before the amp is..
    It's an M-10000 , upgraded to last bios.. Now everything (ehrm, almost) works like it's supposed.. Only need get widescreen res. and the new m.e. 2.0 ... :-)
  1. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 09:30 AM
  2. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
  3. winamp or media player IR remote control for 9 pin serial port $11
    By sfrechet in forum General Hardware Discussion
    Last Post: 08-10-2002, 12:02 PM
  4. serial port shutdown signal
    By moahdib in forum Power Supplies
    Last Post: 08-03-2001, 09:52 PM
  5. 1 serial port, 2 devices
    By Meatballman in forum General Hardware Discussion
    Last Post: 04-16-2000, 11:50 PM
