Results 1 to 10 of 13
Thread: Running remote signal to amp from parallell or serial port?
    Jan 2004
    Hi! Is it possible to have the amp turn on when windows is ready, and not when the machine is turned on? I'd really like this, because the start-up beep on the EPIA M-10000 is REALLY annoying..
    Any other way to bypass this problem is greatly appreciated!
    Variable Bitrate mutilator's Avatar
    Jul 2002
    Staffordshire - united kingdom
    how about off the psu? or would you still get a beep. altho i dont think mine beeps anyways, m10000
    tom.
    Jan 2004
    Well.. If i run it off the psu, it would still beep.. I need the amp to turn on AFTER the posting is done.. What bios do you got?
    Oct 2003
    ummm maybe you could make a parallel controller of some kind (don't ask me on how!!) but maybe set it up to send a signal to the parallel port on boot up and then that would act as your remote wire on your amp... thats the only way I could see it being done, but you would have to create the hardware and software from scratch... have you tried to search the forums at all?
    New CarPC on the way again I think. I miss my old one!!!
    Jan 2004
    Yes, I've tried searching.. Well, back to the drawing board... :-)
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Quote Originally Posted by burnout.no
    Not well enough, evidently
    This thread has everything you really need for XP, as well as a link to a relay controller card
    Maybe the front-end software you are running could be adapted to include something like this? I know for one I am going to ask coyote to add something like this for MediaCar, as it will be useful for me
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Jan 2004
    Quote Originally Posted by Confused
    Oh yeah, I must be blind! Sorry about that.. Thanks for the link! That start-up sound is truly annoying! Anyone else that has it..?
    Aug 2003
    Essex, England
    I'm SURE that they have removed the startup beep from the M10000...i have one...and there is no beep
    You must be running an old version of the BIOS.
    The only thing I get is a "thump" when i turn it on with the amp on, and a "thump, WHIIIRRRRRRRRRRRRrrrrrrrrrrrrr....." when the computer turns off with the amp on.
    If i can get coyote to include that in MediaCar, then that will be very useful
    Garry
    www.aimee.cc
    Jan 2004
    Hmmm.. Bios 1.0B or something, downloading a new one now.. :-) *fingers crossed* Just imagine the fun.. 4speakers + 1sub, 100% volume, and that start-up beep at 02:00AM.. Enough to give any man a heart-attack!
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Are you using the onboard sound? Because I turned that off in BIOS and use an Audigy PCI card and I don't get a beep through my amp/speakers. My amp powers up at the same time as my PC via a relay. I can hear a little beep from the case speaker but my PC is in the trunk and it's hardly audible.
  1. FS: LCD Controllers - $90.00+shipping
    By infrared in forum Classified Archive
    Last Post: 07-20-2003, 08:30 AM
  2. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
  3. winamp or media player IR remote control for 9 pin serial port $11
    By sfrechet in forum General Hardware Discussion
    Last Post: 08-10-2002, 11:02 AM
  4. serial port shutdown signal
    By moahdib in forum Power Supplies
    Last Post: 08-03-2001, 08:52 PM
  5. 1 serial port, 2 devices
    By Meatballman in forum General Hardware Discussion
    Last Post: 04-16-2000, 10:50 PM
