Results 1 to 10 of 17
Thread: inverter and power drain question
    Oct 2003
    Hi All,
    Xmas has been good and delivered a 650W inverter for me, does anybody know, if I switch the computer off but leave the inverter switched on will this still drain the battery?
    If I put the computer into hibernate how much more current will this draw than the above scenario?
    Cheers
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    If your inverter is a soft start inverter it will always draw some residual current to keep the caps charged and the rest of the circuit in standby.
    If you have an ATX power supply, and you switch the computer off without disconnecting the power lead it will also continue to drain some current to supply the 5V standby line.
    Hibernation: Hibernation is the same as switching your PC off in the above scenario, so it'll drain a little power as well, but no more than leaving your PC off (but still plugged in).
    Oct 2003
    cheers for the reply, just looked at the time stamp, do u sleep? LOL
    i don't think it is a soft starter, there is a rocker switch with a definite on and off position.
    Is the current drain significant enough to worry about or is it more of a trickle that will be more than sufficiently topped up by the normal running of the car.
    Would it help the situation if I had an uprated alternator and 2 deta orbital deep cycle battereies or is this simply delaying the inevitable?
    May 2002
    Australia
    Time? ahaha i wake up early ^^ (i'm also in Australia.. that might explain it?)
    The current drain isn't usually that much.. my guess is maybe 1-2A if you leave your inverter on and leave your ATX PSU in standby mode.
    If you upgraded the alternator and had extra batteries then yeah you probably wouldn't have to worry
    You could always try it first; just carry a multimeter around with you and measure you battery voltage across the battery terminals and make sure it doesn't drop too much (too much is when it's less than 12 volts). If it drops that much then start doing stuff.
    Oct 2003
    Australia, summer, nice......
    UK, winter, sux.....
    OK good starting point, cheers for that.
    When u say start doin stuff.... like what, the only obvious thing I can think of is to switch off the inverter.. but.. won't that kinda kill the required power needed for the computer to be in hibernate or am I misunderstanding hibernate, it does need power doesn't it, albeit a small amount?
    Cheers
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Hibernate mode doesn't need ANY power.
    It writes what is in RAM to the hard drive, and then switches all power off.
    When you turn it back on, it reads back from the hard drive into RAM, just as it was before
    So, you could turn the inverter off.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Nov 2003
    one question: for your opinion, how long could you use the carpc with the engine off and whitout damage the battery ???
    My future system, will use a Morex 55w DC-DC.
    Thanks in advice
    Max
    Aug 2003
    Essex, England
    bambuzo,
    It depends on the power draw of your computer, and the capacity of the battery.
    Oh, and if if you're going to buy more stuff...i SERIOUSLY suggest getting yourself an Opus. For what you get, it really can't be beat. I am going to be getting myself a couple in a couple of months (as you see in my sig, i have 2 cars, both of which will eventually have fully-fledged carputers in them!)
    Garry
    www.aimee.cc
    Nov 2003
    Yes, the Opus solution ( as the ITPS i think ) it's the good one, but with it , i'm out of budget for this pre beta test.....
    The inverter's way is the most cheap at the moment...
    Thak u for the reply !
    See ya
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by bambuzao
    Thanks in advice
    Max
    Normal car battery will get bad if you drain the battery 3-4 times.
    The question of how long can you leave the computer running with the engine off is depend on the battery capacity and how good the battery is and how much power the inverter is using. So the duration is depend on the health of the battery and its capacity and efficiency of the inverter and PSU. If you system is actually using about 150W of power, the battery may have to supply more than 150W (said 200W)
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. inverter question
    By johnyeros in forum Power Supplies
    Last Post: 05-21-2004, 02:21 PM
  2. UPS power backup as inverter?
    By CA 3000GT in forum Power Supplies
    Last Post: 02-13-2003, 01:52 PM
  3. power inverter question
    By detz in forum Power Supplies
    Last Post: 07-08-2002, 07:27 AM
  4. Power Supply & TFT LCD question
    By VegaBOND in forum General Hardware Discussion
    Last Post: 03-23-2000, 06:07 PM
  5. 300 watt power inverter problems
    By DaPyro in forum General Hardware Discussion
    Last Post: 03-10-2000, 02:56 PM
