Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: How to bypass headunit using stock amps
    Dec 2003
    Surrey, BC, Canada
    How to bypass headunit and still use stock amps
    I want to make my carputer replace my head unit. My car is a Ford Probe GT with premium sound and as I understand it has a stock amplifier after the head unit. I just need to know how to hack up some RCA cables (minijack to RCA from my line out on the soundcard) in order to make them go to the 4 speaker + and - wires on the wiring harness. Like when I cut off the RCA plugs, how many wires will be in there and which will be the + and which will be the - ?
    And also, since there is only 2 RCA plugs coming out of the computer (white and red) how will I make it go out to 4 speaker + and - wires on the harness (8 total connections to be made) since there will only be probably 4 wires coming from the RCA, 2 for each channel?
    I hope this makes some sense and somebody out there can help me out.
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    I'd get a soundcard that can handle the number of channels your pumping to. I wouldn't cut any RCA cables up, just get some mini to RCA cables from radio shack.
    FYI, you're the seccond person to ask about this in the last couple of hours. Look arround a little bit more and you'll find lots of answers.
    Rob
    car computer rev 5: 8" lilliput and usual suspects
    Dec 2003
    Surrey, BC, Canada
    Quote Originally Posted by robiewp
    Rob
    The thing is that I don't even know if my stock amp would have RCA inputs... would it? If not then my only options are to use an aftermarket amp or to cut up the RCA cable. I just want to know what an RCA cable is composed of, is it just 2 wires per channel or what?
    BTW, I would be using mini to RCA cable but just cutting the RCA ends off.
    Maximum Bitrate orangewhip's Avatar
    Apr 2001
    Surrey, B.C. Canada
    Quote Originally Posted by Bobby Digital
    From what I understand, you cannot just simply cut your RCAs and connect them to your amp input wires (unless you have RCA inputs), as RCAs are low level lines and speaker wires and high level lines.
    I was looking into this a while back and there are a few low level to high level converters but they are fairly $$. Somebody correct me if I am wrong here, but this is what I understood.
    OrangeWhip? OrangeWhip? 3 OrangeWhips!!
    www.whipflash.com
    Finally a new Avatar!
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    You might want to keep in mind that it's rare to have true surround sound in a car. It's a BIG distraction, and difficult to get "tuned" in properly anyhow. Your basic headunit will take two channels and split them accordingly. I would suggest digging in and getting a good look at that amp. If it has RCA inputs, great! Feed it direct from the carPC and listen to the music! If not, then you are likely dealing with something proprietary, in which case you would be better off just spending a little dough and buying an aftermarket amp to power the speakers. Some amplifiers accept left/right input, and split each channel to feed front/rear speakers. If you ARE looking for surround sound, then I would recommend a pair of amps. Feed one with front channel information, and the other with rear.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Newbie awh4992's Avatar
    Jan 2004
    hey...i have a ford as well, and the seperate amp ur talkin about does not have rca inputs. it takes the speaker output from the head unit which is already amplified and the seperate amplifier amplifies the sound even more from there. you could hook up ur computer sound out to that seperate stock amp, but the sound will not be anywhere near as loud as coming from your head unit. if you're using a good ol soundblaster as your sound card, usually u'll have an output which is amplified by the card's onboard amplifier. that will definately work better than just line out to that other amp, but it still won't be as loud as from the head unit as the soundblaster's amplifier puts out something like 4 watts into an 8ohm speaker. you qould also hafta chop a cable which has a 1/8" stereo jack on the end of it. also as was said before, surround sound in the car is a pain, so you could hook up the cable to the amp as the head unit does: left channel out goes to the front and back left channel inputs, and the same thing w/ the right channel. also, since ur head unit is a stock ford head unit, i'm 99.9% sure it won't have any kinda aux inputs of any kind on it, unless it supports a cd changer. so basically....get a head unit w/ an aux input (like a pioneer that supports a cd changer or a jvc w/ a 1/8" stereo input jack) and that'll make life a whole lot simpler.
    Oct 2003
    I am having the same "problem" with a Monsoon system in a Passat. What I will try to do is hook up an amp output the input of the stck crossover amp.
    Cheers,
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    Ditch your head unit and buy an inexpensive (~$150) 4 channel amp and an Audigy card ($75). Then you can output from your sound card (front R/L, rear R/L) right to the amp. Get another 2 channel amp if you want/have more speakers. The Audigy software lets you set up and tune any combo of channels and speakers (4.1, 5.1, 6.1).
    Oct 2003
    I am ditching the head unit. The problem is that with monsoon systems you have 4 tweeters and 4 subs, 2 on each door and hte stock amp/crossover sends the appropriate frequency to each speaker.
    I think its easier to use an amp and send speaker level input to the stock amp/crossover.
    Cheers,
    Dec 2003
    Massachusetts, US
    why don't you tell us? if your car were in my driveway I'd go out and look at it
  1. What`s your favorite headunit....Aux in
    By PORTUGAL in forum General MP3Car Discussion
    Last Post: 11-22-2003, 10:30 AM
  2. Anyone using the headunit as a am/fm tuner into carputer?
    By -al- in forum General Hardware Discussion
    Last Post: 10-27-2003, 07:52 PM
  3. Will stock alternator provide adequate ampage? (CPU + Sub)
    By Cadillac_LoungN in forum Power Supplies
    Last Post: 07-07-2003, 02:52 AM
  4. Audio and amps - building a preamp.
    By claylong in forum Power Supplies
    Last Post: 03-26-2002, 10:45 AM
  5. how to feed audio to headunit and shut PC off
    By BluCivic93 in forum General Hardware Discussion
    Last Post: 07-03-2000, 06:08 AM
