Results 1 to 10 of 11
Thread: on board network card problem with m10000
    May 2003
    for some reason, when i enabled network...and plug the cable into my router...the icon in the right bottom corner keeps blinking and saying that the cable has come unplugged. It is blinking that message, meaning that the cable is like being plugged in and pulled out constantly....but of course, im not doing that. I've tried 4 different cat5 cables and plugged it in different ports and still the same problem. I also reinstalled the network drivers also...anyone experienced the same problem? Any idea how to get around it?
    May 2002
    easy, don't use windows, you won't have problems
    I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
    NavSys, the ultimate navigation app
    http://www.navsys.org/
    May 2003
    please stop spamming all the posts with your anti-windows comment. Linux is not the solution to everything around here. Stop trying to be funny, no one is laughing.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Sounds like the NIC is bad...Maybe a cold solder??? Look the Motherboard over real good and make sure there's no scratches. Other than that I would say an RMA is in order.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    What are you using for power? If you're using a PW-70 or something similar, what are you using for regulation? five USDs says that if you plug in a normal ATX power suply your problem will go away
    car computer rev 5: 8" lilliput and usual suspects
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by robiewp
    ...or what he said.
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    Registered User belezeebub's Avatar
    Dec 2003
    I have seen this issue with Windows 2000 and a SMC chipset nic the fix was to shut off auto detect and hard set the card for the hub 100/ full 100/half what ever your hub or connection needs.
    Quote Originally Posted by Defiler
    ...or what he said.
    Jul 2002
    Boston, MA
    I heard heard the same when those power supply's first came out in the casetronic's case.
    There wasn't enough juice to power the nic with all the other devices...
    -Mario
    May 2003
    i have the pw70a with itps, BUT im not using that as we speak. Im using a normal atx power supply to install software in my house. So it CANT be the power supply
    Jun 2003
    Chicago
    Quote Originally Posted by [H]Bugster
    The onboard NIC on my Epia 10000 doesn't seem to work either. It's been a while since I tried it but I recall seeing the same errors. I was going to wait a while to RMA hoping that the vendor would have to upgrade me Nehamia core instead of the Ezra I currently have. I'll have to try using an ATX supply to see if that helps.
  1. EPIA on board gfx + 7" widescreen LCD = problem?
    By phoTToniq in forum General Hardware Discussion
    Last Post: 06-23-2004, 07:12 PM
  2. height of M10000 w/ Riser card
    By Lando in forum General Hardware Discussion
    Last Post: 10-17-2003, 09:24 PM
  3. Dennisk controller card problem
    By helmuteke in forum LCD/Display
    Last Post: 07-25-2003, 08:11 AM
  4. pcmcia card reader and pcmcia modem problem
    By dekodan in forum General Hardware Discussion
    Last Post: 05-24-2001, 12:04 AM
  5. Sound card and network card
    By Matthew_sl in forum Software & Software Development
    Last Post: 01-31-2001, 03:29 PM
