Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Carputer Condensation
  1. #11
    Nov 2003
    Colorado
    Quote Originally Posted by TruckinMP3
    Hey Sigma,
    I assumed (bad of me) that I was the only member in the Denver area.
    You acctually have cold boot issues here?
    Yes, I have cold boot issues in the morning. If it's been below freezing it usually takes 5-10 minutes before I can get a good boot.
    The conventional wisdom in these forums is that cold weather problems are hard drive related, but I'm no longer sure that's true. Recently I've done some experimenting with different hard drives, and they all seem to behave the same. I also tried using a removable drive bay and removing the hard drive at night. This also did not make a difference. Therefore, my new theory is that the PW-60 power supply I use is the problem. Perhaps these small DC-DC power supplies do not put out enough current in cold temperatures. (They are only rated to 0C.) Anyway, I'm going to try a regular ATX power supply (through an inverter) for a couple days, and I will post my results in a new thread.
  2. #12
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by sigma957
    SNIP
    Interesting, I am using the PC power and cooling 12 v PS and have not had trouble.... But I am garaged most nights now. (home ownership perks).
    I'll watch for the update on Boot reults.
    TruckinMP3
    Read the FAQ!
  3. #13
    Nov 2003
    Colorado
    I used to be garaged every night, but between my wife's minivan and the kids bicycles, my car seems to have lost its spot...
  4. #14
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    What about running a lead from the engine block heater into the computer case. what kind of heating element should be used(AC current).
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
  5. #15
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    well then the solution is obvious! give one of them the boot.
    car computer rev 5: 8" lilliput and usual suspects
  6. #16
    Maximum Bitrate gork's Avatar
    Aug 2003
    Amarillo, TX
    Keep in mind that water only starts to be a good conductor when it gets a lot of ions in it via dissolved salts or something like that. A tiny bit of condensation or frost will normally be less of a problem for manufactured electronics than the rapid temperature fluctuations that could cause condensation or frost to form on the electronics would be.
    In any case it's not been a problem for anyone on the boards operating in temperature extremes.
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
  1. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 09:57 PM
  2. My Chevy Tahoe and carputer
    By reggiek945 in forum Show off your project
    Last Post: 05-24-2004, 12:13 PM
  3. Full carputer stereo replacement? Opinions Welcome.
    By jasonsp6 in forum General Hardware Discussion
    Last Post: 12-27-2003, 12:42 AM
  4. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 11:10 AM
  5. help - starting up carputer
    By tilezzzzz in forum Power Supplies
    Last Post: 06-18-2003, 01:52 PM
