Results 1 to 10 of 10
Thread: Any Epia M10000 Owners Having USB Detection Problems?
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    Well I've had my truckpc running for a couple of weeks and the biggest problem I'm havings is that my USB devices (touchscreen on Lilliput, M-Audio Sonica sound card and Earthmate GPS) don't get detected about 50% of the time on start up. I installed an pc powered hub that these devices attach to. Sometimes I boot up and they're working and some times they don't. Anyone having the same problems. I'm running XP Home SP1, 512 Ram, Notebook HD, Notebook CD/CD-RW drive. I've seen some information over at Microsoft saying that it might be a known problem that will be corrected with SP2. I tried to get the patch already, but because I have an OEM license (yea I actually spent money on a license) MS won't give me the patch to see if it solves my problem. Anyone have a suggestion? Any way through software to simulate a plug unplug of the USB cable?
    Jan 2003
    Ruston, LA
    Have you hooked them up without the hub ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by frodobaggins
    Yeah, It'll be the hub, get a powered one.
    Oct 2003
    I was having the same problem before I had the hub with the touchscreen and the gps hooked directly into the back of the computer. The only reason I don't think a powered hub will help is that the hub is working all the way until windows takes over during start up. I can see the light on the sound card is on and then it's like windows resets the usb devices and sometimes they come back on and sometimes they don't. I saw a powered hub that drew power from a second usb cable-this solution would be easier than having to scab in something for +5 volt, but I'm guessing if I'm not getting power to the hub from one usb port that I probably wouldn't get anything from a second.
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    what kind of psu you running?
    i have issues w/serial devices w/my pw70 cuz i have so much crap hooked up to it...
    good thing i got an opus 150 sitting right next to me now
    Oct 2003
    Quote Originally Posted by 00CericaRuss
    It's a PW style that came with my Cubid 3677 case. I guess this could be a problem, but I'm within the power limits of the power supply. It's not like I have a problem running everything once the usb devices get connected. It's just that half of the time the computer starts up and I have usb devices and the other half of the time I have to unplug/plug the hub cable.
    Oct 2003
    Quote Originally Posted by Laidback
    You're absolutely correct. I bit the bullet and spent $30 on a "powered" hub and my problem has gone away. I bought a Targus USB 2.0 hub from BestBuy. The reason I chose this hub was because power is supplied by using a second USB port on the computer. Anyway, it's worked perfect so far.
    Maximum Bitrate tom2112's Avatar
    Nov 2003
    Sharon, PA
    Quote Originally Posted by rgardjr
    Can you give us a model number or link to that hub?
    So far:
    M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
    Oct 2003
    Quote Originally Posted by tom2112
    http://shop.store.yahoo.com/pcsound/849065.html
    http://www.staples.com/Catalog/Brows...12751+++++++++
    Not sure if this applies or is useful: http://www.viaarena.com/?PageID=298
    Under Win2000/XP: This patch will save all register values in the memory before a system enters Stand By mode and then restore those registers when the systems resumes. This therefore avoids the situation where USB devices are not ready for use after a resume from Stand By mode.
  1. 1Gb RAM for EPIA Owners - Compatible
    By tom2112 in forum General Hardware Discussion
    Last Post: 01-28-2006, 12:15 AM
  2. Will this VIA EPIA M10000 setup work properly??
    By b5b4you2 in forum General Hardware Discussion
    Last Post: 01-20-2004, 10:12 PM
  3. v10000 epia vs m10000 epia
    By traitorhound in forum Newbie
    Last Post: 11-27-2003, 10:19 AM
  4. Replies: 6
    Last Post: 07-21-2003, 03:18 PM
  5. Via Epia Questions - need multiple serials, ps/2 ports, USB
    By nxt125 in forum General Hardware Discussion
    Last Post: 08-07-2002, 09:08 PM
