Results 1 to 8 of 8
Thread: Where to connect extra fan?
    Low Bitrate Richie's Avatar
    Sep 2003
    Sweden - Stockholm
    Hi guys!
    Almost done with my ITX-carputer built in a nice box (you'll see )
    I only have one problem, since I'd really want to keep the original ITX-fan on the heatsink and still use an extra fan 8x8cm on the top of the box to blow out hot-air... Is there any posibilty to connect it to the ITX M10000 N board or do I have to connect it to the Opus? (90W btw.)
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    If it's got a 3 pin "tail" on it, then there will be a header on the motherboard right next to where the CPU fan is plugged in
    If it doesn't have a 3 pin tail, then you will need to connect it into your Opus
    Confused
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    there is a sysfan connection on that board, near the ATX power connector and between the processor and VGA out jack
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Sep 2003
    Sweden - Stockholm
    Tnx guys for fast service!!! =)
    Quote Originally Posted by Confused
    Confused
    Yeah It's a 3pin (red, yellow, black) though I couldn't find a place there =/
    Quote Originally Posted by wizardPC
    Found that one... And there I can connect any fan?
    Aug 2003
    Essex, England
    Yeah, almost any fan, but of course not one that draws too much current, otherwise it may blow the header Normally about 0.5A is the max current
    Garry
    www.aimee.cc
    Sep 2003
    Sweden - Stockholm
    Garry
    Cool! This one's 0.25A so I'll try it then!
    Thanks alot guys!
    edit: do I have to shut down CPU while connecting?
    Aug 2003
    Essex, England
    It's best practice to always turn it off when plugging in/unplugging stuff...but i almost always plug in fans when it's turned on
    If you do though, it's your fault if you break it :P
    Garry
    www.aimee.cc
    Sep 2003
    Sweden - Stockholm
    Garry
    HAHA! tnx... didn't want to ruin the uptime until I would put in my car... but well well.... what can you do if you want to be shure not braking anything...
  1. Can I put an extra battery in my Chevy?
    By Mastiff in forum Power Supplies
    Last Post: 11-04-2008, 12:45 PM
  2. PSOne monitor (again) how to connect to TV-Out
    By Daninino in forum LCD/Display
    Last Post: 09-23-2003, 02:32 AM
  3. Vantec Vibration Dampener make fan moist?
    By phc in forum General Hardware Discussion
    Last Post: 09-11-2003, 10:06 PM
  4. Replies: 0
    Last Post: 09-02-2003, 02:09 PM
  5. fan directly pointed on an opus?
    By samc in forum Power Supplies
    Last Post: 08-21-2003, 09:36 PM
